Miksweets
Mine is to restart the computer so I can clear the 2 codes I have picked up
Tomorrow morning it's getting an alignment. After that, my next big thing is to pull the tranny and fix wherever my fluid is leaking; I plan on changing the drive shaft / front pump seals & the dipstick o-ring.
While I have it out, it's getting an j-modded '04 valve body & 2800 stall converter installed!
Next big mod is I have a set of heads going for 3-angle valve job, a little P&P action, beehive springs, & Cobra cams.
Nice! I like your list. The converter seems a little whimpy but better than nothing.Spin it high tough guy. Your car will LOVE the rpms with the beehives in place.
+1 to hairdryers! I prefer vortech over Clairon. Seems to push a little bit more air.![]()
Yeh, I got a good deal on the converter that I couldn't pass up! Like you said, better than stock!
When I 2nd gear brake-stall the stock converter, I get 2400 on the tach - if I can get that up to 2800 or so, it should be a noticeable difference don't you think?
Pulling original motor, swapping it with 04 terminator forged bottom end, with p&p 98 cobra heads. Upgrading fuel system with 80lb injectors, AEM fuel rails, and a larger fuel pump!!!
I assume the bearing is going out on the water pump, getting pretty scrape-y when you turn it by hand and it squeaks off and on while the car is running. So I need to do that.
Not looking forward to it. Don't know how I''ll refill the system, the crossover tube cap hole-thing to take it off was rounded off by whoever owned the car prior to me.
