What components do you guys have?
jcavz24x
FL
I got my HU installed with a 4 channel amp. Still running stock speakers which actually sound pretty good for stock. I am planning on changing all 4.
Any of you have any components up front? which ones? 5 1/4", 6 1/2"?
Chris
Chris
5.25 MB Quart QSD213
Boston 6.5' components up front and Boston 6x7 components in rear. and Kicker 6X9's in the rear deck. Whats the RMS wattage on your amp?
Good quality amp..65x4 RMS @4 ohms 85x4 RMS @2ohms.. you have model #s for the bostons?
Chris
I am running MB quart PCE 6.5" in the fronts and MB quart PCE 5.25" in the back doors.
Did you guys use ford speaker connectors or cut the factory wiring?
Leo...did you use adapters for the 5.25"?
undercover, simons..WHat did you guys do to make the components work with a sealed fit?
jdsimons...Do you have tweeters in the back too? is everything amped?
Chris
Chris
cut the factory wiring.... still working fine to this day. i put mine in not long after i got the car 2 years ago.
this is exactly how i did it: http://www.sounddomain.com/memberpage/348671/4
If your worried about putting the factory sp back in later either leave enough wire on the plug when you cut it off to reconnect it or leave the factory plug, strip the wires back before the plug and solder the new wires for the new sp.
Those connectors are a joke, no professional installer I have ever worked with liked them. Just one more connection to go bad. It was just another ploy to remove $10-$30 from your wallet. Cost is $4 or less.
Just my oppinion.
Chris
Well we used dynamat extreme and did the whole inside shell of the doors and we cut some templates to bolt into factory holes, then i just used those styrofoam baffles. I had those in an old car stereo i competed with and kept them looking like brand new for years, and they sounded very good. Ya, all components are amped.
