NoLimit95
I know there's a way to go into the steering column and do a splice to keep the lo beams on when the brights are turned on or have just the lo's on; this mod needs to be done with an HID conversion on the lo beams to keep from killing the ballasts with on/off/on/off
there may be downsides to this configuration, what are they?
after pix
[url]http://s1245.beta.photobucket.com/user/dnsherrill/media/grilllights2.jpg.html[/URL]
[url]http://s1245.beta.photobucket.com/user/dnsherrill/media/grilllights1.jpg.html[/URL]
No downsides.
Remove the upper steering column cover by taking out the ignition lock cylinder and four screws. The lower part of the cover will also come loose.
Then, locate the two torx screws holding the multifunction lever switch and unfasten them. (Torx-20)
You will find two connectors on the multifunction switch. The smaller one has two rows of pins, one with three and one with four. On one end of the four pin side, you will find a red/black and a red/yellow wire, contact numbers 13 and 15, splice number 270 if I recall correctly.
Just connect these two terminals with a suitable piece of wire and you're done. No relays, almost no extra wiring, no hassle, no computer interference.
Repeat the above steps in reverse order to reinstall.
5000K HID kit or 6000K HID kit with some clean housings. Halogen housings work just fine and take the 9005 bulbs. That's what I use. Well, I'm using 6K and 10K bulbs right now but I have some extra 6K boxed up if needed but I don't need my highs for anything.
