thaywood
Explorer a 4x4?
Yep. 4x4, manual locking Warn hubs, low-range, Twin-I-Beam IFS. Tough as a tank. Not like the newer ones. I love my Exploder!!!
Explorer a 4x4?
I'm sorry, those have leaf springs on all four corners don't they?
Really?
Yes really. They're the kind that have a shock at both ends iirc. Pretty cool setup.
our F250 HD has leaf springs at all four corners.
You may be thinking of the older Broncos. This is the first gen Explorer with the twin-I-beam setup with coils on top of the I-beams and shocks mounted behind the I-beam and a radius arm connecting the I-beam to the chassis. Coils and shocks up front and coils and leafs out back.
You can clearly see what i'm talking about in the picture. From what i've heard it road pretty well though.
I'm not entirely sure I know what you're talking about but it does ride fairly well. Still rides like a truck, but a good riding truck.
Super Duty with a straight axle in front? I've seen those. Some of the Excursions had that too. Those are seriously heavy duty. I think only the 4x4 Super Duty chassis had solid axle front suspension with leafs. The 2WD models still use the good ol' Twin-I-Beam.
See where the two rods enter the shaft? Look to the right next to the frame. On the other side you can clearly see it if you follow the linkage from the center reamer rod in the illistration.
The Explorer's Twin-Traction-Beam has coil springs, not leaf springs.
I don't quite get this statment. There is a shock at all four corners of the vehicle. Two in front and two in the rear. I may be having a brain fart but I have no idea what you're talking about.
I really can't see what you're talking about. I need a little bit more info. Again, maybe a brain fart.
Are you talking about the radius arms that connect the two I-beams to the chassis?
Here's a good view of the front of the Twin-Traction-Beam IFS.
And here's an exploded veiw:
There are no leaf springs. And there is a shock absorber mounted to the radius arm just behind the coil spring. The coil sits right on top of the I-beam on each side.
Oh yeah, I forgot, the 2WD models were called "Twin-I-Beam" while the 4x4 models got the name "Twin-Traction-Beam".
...I'm getting ready to do LCA's and SRB's. I need to let the air out of the front springs to do that...
Parked it about a month ago while I was gathering my front end part's together. Jacked it up today with the air ride switch off to get nut and bolt sizes. When I lowered it, I started it up cause it sit's a little high after jacking and my air compressor isn't kicking on and it isn't venting either WTF! No air ride message either.
Is there a simple test I can perform or maybe I should take it for a little ride? I'm getting ready to do LCA's and SRB's. I need to let the air out of the front springs to do that. I'd hate to do all that work and then it not air back up. Front air spring's and compressor/drier can't be more the 5 years old with only 20K maybe on them. Dam if it ain't one thing it's a dozen other's! I love this car but I'm beginning to wounder if she love's me back![]()
