Nakoa
U Giyz R All Wrong N Dumz My Towncra Will Beet Ne Of U Dudezez Carz. How Cud U B So Dum??!!
......... Uhhh......... What?U Giyz R All Wrong N Dumz My Towncra Will Beet Ne Of U Dudezez Carz. How Cud U B So Dum??!!
You guys are comical!!! Have either of you ever driven a Cobra on a road course? Do either of you have competition licenses? I have competition licenses issued by NASA and BMW CCA. I also instruct at BMW CCA driving schools on race tracks.
......... Uhhh......... What?![]()
Did you mean to say, "You guys are all wrong and dumb. My Towncar will beat any of you dudes cars. Home come you are so dumb?"
It's hard to read dumb....![]()
Okay... so you're telling me numbers arn't everything. Yes, you're right they arn't everything... But if the LS is so track worthy, why is it almost no one races their LS?
Again... you are giving a sports sedan a LOT more credit than it deserves. The car was never designed to see track duty; it was designed to be a capible street car.
Mis-marketing (didn't generate a large enthusiast following), virtually zero aftermarket, discontinued vehicle, high vehicle price (till recently). Those factors are what come into play that determine that the LS does not see much track-time. Is lack of a large RR following the automatic determining factor for saying "The LS isn't a potentially worthy RR car"? No.
Once again, you are only thinking in absolutes. There is much more that happens behind the scenes that you would be well served to take into account.
Same goes with your Cobra when it comes to giving a vehicle more credit than it is due in a certain area. The Cobra was meant for dragracing and the LS as a Sporty Sedan. Neither were designed to do RR'ing duty, but they can hold their own fairly well in the mix of other stock vehicles on the market today.
Okay... so you're telling me numbers arn't everything. Yes, you're right they arn't everything... But if the LS is so track worthy, why is it almost no one races their LS? And I'm pretty sure the 99 and 01 cobras aren't too far off from 50/50; what you're forgeting is that the IRS unit in the rear ADDS weight to the rear of the car over a straight axle set-up. Look at the weight figures; the Cobra weighs more than the GT, however the GT has the Iron block 4.6L, Cobra runs an aluminum block... That's a weight savings up front. So where does the additional weight on the cobra come from? The IRS unit that is bolted up to the straight axle mounting points on the Cobra (as ALL mustangs share an identical uni-body). I'd have to do some research to give exact numbers... which I'm not inclined to do right now, but it's much closer to 50/50 than you think.
And back to the numbers... you speak of power curve... and how the LS gets its power higher in the RPM band, and how that's perfect for road courses, and a higher displacement V8 with its power band lower in the RPM scale isn't going to be as good... How do you explain the Viper and their huge displacement V10, along with the Diesels that Audi runs (both have been HIGHLY sucessful in their class)? It's all about transmissions and rear gear ratio; where the engine makes it's power has little to do with it's performance on the track. Gearing is much more important.
So, to make up for the lack of power and torque, in addition to the added weight... in aspects of suspension... you'd have to be pitting a 1960's suspension against a 21st century fully indepedent design.
Actually, the Cobra was not really designed for drag racing. As with most IRS cars, the Cobra suffers from wheel hop when you lose traction at launch. That's why Ford came out with the solid rear axle Mach 1. To satisfy the drag racers.
First of all, I never claimed anything about the LS power curve. I only supported the assertion that A CAR with less power can make up for some of the deficit with better handling. Nothing more, nothing less.
Let's not forget that the LS chassis is also used by the Jaguar S-Type and the Type-R seems to take advantage of the merits the DEW98 chassis has to offer.
There was a concept at SEMA that took an LS and shaved 600lbs and did a few minor tweaks to the intake exhaust. I don't remember who or what it was called. The problem with tracking an LS is the cost, amount of modification required and lack of off the shelve components. It has a 4-wheel independent, double-wishbone suspension. The possibilities are definitely there. Once these vehicles become more attainable then you may just see a few hobbyist LSs at the track. I really don't think most peope are aware of it's virtues. Are there any Jag S-Types being tracked? I honestly don't know.
It was only in response to 99 Kobra that I stated my opinion that the LS could beat a Mustang IF it were able to achieve the same power levels. This is a hypothetical assertion since it cannot currently do so. What about Rocket5979? What was he able to accomplish with his nitrous setup? Anyone know?
As to the FR500 beating everything in SCCA, isn't that an S197 based Stang? They ARE loosely based on the DEW98(LS, Jag, Tbird) platform. I know some people will say that idea was scrapped, but most of the design phase was already complete so there are many components shared. The differences have mostly to do with the Mustang using struts and a live axle. There is plenty of info on that here:
http://en.wikipedia.org/wiki/Ford_D2C_platform
In regard to the Viper comment, that would be highly dependent on the type of track you choose to race on.
Finally, the assertion that all suspensions after the 60s are equal is quite ridiculous.
I totally agree that the LS suspension is a great design. I wish the Cobra had it! All of my previous comments comparing the LS to the Cobra are based on the fact that the LS weighs more and has less power. If power and weight were close, the LS would smoke a Cobra. However, they aren't, so the LS can't.
Spray is nice, but it is much more suited to a drag strip.
