AmsterDutch
I absolutely agree with Joe ...just out of curiosity what kind of coolant you running in her?Yep, will do that first.
You're fine with that coolant but you can never go wrong running green in the 1st Gen Lincoln LSOrdered the thermostat today, will pick up on way home from work and install. I was running the gold coolant but ended up adding Preston all models (saw a post from Joeger saying that was okay).
Okay lets start from the beginning...what Plastic parts did you replace on the Cooling system rebuild?Okay, another new OEM thermostat ($27!) and new gasket ($17!) and no joy. No leaks and bled system as always. Pressure eventually builds up (including upper hose) as temperature increases. Fan is running. Turn heater on and returns to normal. Help
how many minutes did you let the system bleed? did you try jacking up the back of the car or drive back wheels on ramps while bleeding the system? I know this sounds crazy but times I had to bleed the air I bled the car for about 30 minutes while refilling Degas bottle when needed...if you think all the air is truly out of the system then A. you have a crack you're unaware of or you may need a new water pump...my money is still on air in system or a crackDegas, heater tube (twice), upper and lower hose, and of course thermostat (twice).
I usually fill the degas bottle pass the hot fill mark and allow the coolant to drain out of the bleeder hose for 30 minutes ...after 30 minutes I close the bleeder valve and take it out for a drive to make sure the car is staying at a adequate temp ...if the car overheats after bleeding for that long I know I have bigger problemsDidn't really time it but I watched a video on YouTube as follows; fill system and leave cap off. Run heater. Hold at 2000 rpms for 2 minutes. Let cool and repeat. I did once so far and will do it again later tonight. So just leave the valve open for 30 minutes while refilling Degas? Okay, I know I didn't leave the valve open that long. Will try it.
... Fan seems to be operating normally.
This question has no relation with your over-heating...Did you buy 50/50 premixed coolant? I agree with Jmeecer ...you may want to but UView 550000 Airlift Cooling System Leak Checker and Airlock Purge Tool Kit ...Ya, I'm getting to be a real expert at bleeding the system! I went OEM on everything and the cap appears to be sealing properly. I notice the pressure release when removing. I miss the good ole days... hose springs a leak, replace it and your done!
