Okay, went to remove actuator per YouTube video I saw. Disconnected reservoir hoses and then discovered that I could not access it from the top line the guy did in the video (I guess his was a V6). Decided to have my shop do it and called the dealership to order the part. Found out the part was not the actuator but the control module. In the process of starting the job I sucked out the fluid in the reservoir and refilled it with new fluid when I resintalled it and voila the fan started immediately working. Worked all day yesterday so looked like we were good. Nope, overheated close to work again today and fan was not cycling. So glad running the heater returns the temperature to normal and allows me to get where I am going! Ran perfect on return trip and it was around 110 (I am in Arizona). So question for jmeecer, was the pump you bought on eBay new aftermarket or? Did you install the pump or just the actuator? I did see the post detailing the V8 installation for the actuator. My shop quoted me an hour or so to install it.
