Blueberryyum02
You would have came off better if you would have went to advance auto, and bought the part. Same price wit a lifetime warrenty. Mines went out a week ago, it sat till I got off work been up and running since.
The work involved was removing the air cleaner housing,
Removing the resevior
Unplug the connector
Put your 19mm deep well socket on take a stuby rachet 1/4 or smaller cause it's a tight spot
And work the rachet in small increments to to the space and it comes right off.
Replacing is proceedure in reverse
Snug it up tight but do not make it so tight that the next man have to blow it off, and your good
Fill the system turn wheels till you see air bubbles or a lot of foam, start car let in run for a minute shut it off turn wheel lock to lock top off with fluid let it sit and settle in take it for a drive with lots of left and right hand turns your good.
