I am slowly building up a complete rear sub-frame suspension and drivetrain.
- The subframe is a 2005 LS K-frame with new front differential mounts welded in place to fit a Mark 8 carrier housing.
- Carrier housing is a Mark 8 housing with the axle shaft seal bores modified to fit the heaviest duty off-the-shelf inner CV hub I could find.
- Carrier is fitted with a Torsen T2R 31 splined LSD.
- The seals I used, only available one for this combination, including many hours of calling suppliers and calling manufacturers is: National Seal, P/N 451817. 1.812 x 2.43 x 0.468. (My little secret, now shared with the rest of the world)
The inner CV hub that works for this set-up is from the "Left front" CV joint 1/2 Shaft from 07-'10 Expedition, 09-'10 F150, 4WD Years:2009-2010 (X 2 - one fore each side.)
- I have built up C5 spindle assemblies with 14.4" rear rotors with 2010+ Camaro Brembo Calipers, and the "big plus" to this is the much heavier duty hub that use beefier Corvette CV axles, and has the built in Rotor Parking brake assembly.
- Custom Upper and lower Control arms. (My design, not posting images of these until the complete build is finished.)
- I will be able to use the longer stock C5/C6 splined axle shafts and have the inner end shortened and splined to mate with the Expedition CV spider gear.
- I am using 19 x 12 Corvette rims on back, and in order to achieve this, fender flares are required. Plus in the design of the control arms, I am increasing their lengths (Wider stance) so that the rim's offsets match up in the same relative position as stock Jaguar STR rear rims. ( I didn't want to use rim spacers/adapters, and was worried about more scrub having 4"wider rims further outboard.)
- Coilover shocks and springs are selected, but not purchased. I still have 3-4 other custom parts to purchase before ordering these.
I spent way too many hours trying to find a better/stronger outer hub assembly to use, and I couldn't find any off-the shelf replacements for the hub with that wide press in hub carrier bearing. This outer hub/bearing/spindle combination is unique to the DEW98 platform. This meant that any direction I chose would require more custom fabricated $$$$ parts.
If others chose to put in a 31 splined 8.8 differential, rather than the standard 28 spline, and stick with the stock outer CV stubs, custom splined axles will be required. This alone will cost $600 to $800 for a pair of Driveshaftshop custom splined axles. I was also worried that all of the versions of LS and Jaguar splined axles and CV races are too weak, and you'de have to use 300M axles at a minimum because of the smaller diameter splines that are used. If you have an extra $1500 to $2500, you could save a lot of time and have custom CV 1/2 shafts made. Could save a lot of headaches.
Lastly, I happily shifted to the Vette hub because the ABS reluctors in the hub are compatible with my conversion, Others will have to maintain the LS style Reluctor rings and their associated sensors.
Enjoy!
