I am bumping this thread to ask a few questions! I am trying to replicate what you have done here. I am also trying to make custom beefy axles on a budget. Few seem to have tried this and there is little information online!
Do you have measurements or specs of the Explorer "37 spline" CV axles? I can't find the specs on these anywhere. I believe they must be a different pitch than the standard axle splines (which are 24 spline typically). If you have the major diameter I think I can figure it out. Maybe these CV axles use a metric pitch?
Were the front inboard CVs off the F150/Explorer different than the rear ones? I wasn't clear if you also looked at the rear axles. I was presuming I could try to use rear inboard Explorer CV's, but maybe these are different in some way?
So did you end up machining the differential housing to take the larger truck sized seal? Actually it sounds like you managed to find a special seal that would fit in the axle housing but had the right ID? That is brilliant! I have a lathe and was presuming I could just turn down the seal diameter but this is easy peasy!
Really appreciate all your work on this. We think alike! Hope you are still on the forum after 7 years
Looks like you signed in earlier in the year at least!
