Cool, I just won $20.What are Aero Cobras?
An Aero Cobra is a SN95 chasis Mustang when they were curvy from 94-98. The 96-98 Cobras got the Teksid in them but are not COP cars so their covers wont work.
So to do 98 Cobra complete head setup I would need 99+ valve cover and can I use the mark VIII intake mani etc?
...the only gripe I had was being generalized as stupid.
Perfect time for a C head swap.
Ripped, I really dont think this is the proper time to be contemplating headswaps...that requires FAR more planning than a simple Valve cover job.
If I were you, I'd be getting a running MARK8 motor put in there, so you can continue to drive the car, while properly planning and executing a C head swap, or a cobra conversion.
Labor is gonna be alot less if you simple "remove and replace".
I know you want to come out "better than before", but.. Rushing into this second step of your adventure is just as bad as rushing thru the first part of your adventure.
There will be many that "cheer you along" into a swap or conversion.
But.. you really need to focus on the goal at hand, which is recover from your previous mistake, and not make additional poorly thought thru knee jerk reactions.
 Which is why I want the best bang for the buck.
  Which is why I want the best bang for the buck.  Some say yes but I say no. Only the 96 Cobra cams were slightly different, they were better on the top end.
As for your cams dropping in I think not eaither as you would need them to have their wear marks match. You are really better off getting a whole new engine and slapping it in. Degreeing a 4V cam (well all four) isnt an easy thing to do and even Ford messes it up.
96-98 Cobra cams are the same p/n.
If I buy a complete set of heads with cams and all in it, then I wouldn't need to degree them would I?
You are right, they are. BUT the production 96 Cobras have slightly different cams. Should you order a replacement cam then you get the revised settings.96-98 Cobra cams are the same p/n.
So that means they are the same or are different than the mark cams?
How difficult is a C head swap? Does that require a different computer too? Or will my SCT tuner be sufficient.
