chris2523
93 Mark VIII
these arnotts suck.
to clarify, both front and rears hold air admirably. weeks on end. the front shocks are much to soft. the rear bags are fine. especially with cobra bilstein shocks.
these arnotts suck.
soo.. to clarify, can i use stock struts/ springs from a Thunderbird? i have a limited budget after all the suspension work so far, and theres one in the yard that looks like it has almost all new struts/springs. i did take one off and test fit it ( on the front) of a gen 1 mark viii. and it bolted right up no problem. but im not sure if the 2nd gens are different.
How much are Arnotts now Chris?
actually, i can't find any. american air, ebay, nor arnott's website has any.
and suncore industries still sells the front and rear air shocks, they even have re manufactured ones, at a cheaper price of course.
I haven't checked Suncore's prices lately. But I would hope that they would be under $200 each given that they're old Arnotts.
What good is a new air spring with a worn out shock?
Just be smart and add $85 to it and get the real thing. You can't go wrong. I just took mine on an 80 mile round trip, mostly HWY and the ride now is unreal. When it goes across those small bridges that kinda hop you up and down... now mine is just gliding across them with almost no hopping at all and very smooth. The 16 cost more than the 17 for some odd reason but well worth it IMO.
[URL="http://www.amazon.com/Motorcraft-AVS17-Spring/dp/B0011DTY2U/ref=sr_1_1?s=automotive&ie=UTF8&qid=1339613178&sr=1-1&keywords=AVS-17"][url]http://www.amazon.com/Motorcraft-AVS17-Spring/dp/B0011DTY2U/ref=sr_1_1?s=automotive&ie=UTF8&qid=1339613178&sr=1-1&keywords=AVS-17[/URL][/URL]
[URL="http://www.amazon.com/Motorcraft-AVS16-Spring/dp/B0011DSB6K/ref=sr_1_1?s=automotive&ie=UTF8&qid=1339613522&sr=1-1&keywords=AVS-16"][url]http://www.amazon.com/Motorcraft-AVS16-Spring/dp/B0011DSB6K/ref=sr_1_1?s=automotive&ie=UTF8&qid=1339613522&sr=1-1&keywords=AVS-16[/URL][/URL]
$310.80
$285.83
$596.63 for 15 years of worry free front air shocks.
Wished I had found these prices before I done mine. In total, I paid $723.00
-596.63
$126.37 in savings. I just need one more and I'll have another complete front set for the closet. Never know when there won't be anymore in stock anywhere.
Hopefully those prices will stay relatively constant until tax time. Then I might be able to get a set
i think it's mad because of the wheels you have on the car. :d
j/k. Dude, sounds like your ride height sensors may be causing the issue but then again, don't listen to me. I went through 3 years of dealing with air ride issues on my marks & finally converted to springs on both my cars.
car has been converted. used everything from a v6 thunderbird.rides MUCHH better. but i have warranty/ exchange on all the parts. ive heard that the v8/SC thunderbirds sit lower, true?
A V-6 Thunderbird? Mark VIII's are a lot heavier than V-6 Thunderchickens.
Have you noticed any floatiness or bottoming over bumps/dips?
That's what I thought until DLF posted on the other forum when this topic came up. He owns both cars and they are within 10# of each other according to the track scales. The GVWR ratings on the door tags between the Mark VIII and SC Thunderbird shows that they are VERY close in weight.
NOPE.
But...an SC has stiffer springs than a stock V-6 T-bird. I figure the SC springs are similar to the Mark VIII while the stock V-6 T-bird's would be substantially softer.
so is it only the SC that has the stiffer springs? not the v8 TB also?
SC's and Sport Model 4.6's with spring code JJJJ
