Sergmark said:I guess I'm lucky. (MAybe small hands) I put mine on hand tight and take it off with my hand and just snake it around the lines it almost falls out.![]()
JC1994 said:was your filter seized on?? I can get mine off and on and, in and out with no problem. I use a Motorcraft filter.
m_maker said:What lines are you running ?
I'd like to see pictures of this setup.
Dominus said:Must have been. Even with the screw driver, it took half the weight of my body to get it to move at all.
I didn't put that filter on, so I can't say how it was done. Whoever did it must have been a sadist.
Moes8 said:can some one recommend a remote filter kit for me?
thats how i do it use motorcraft filters and the MAC TOOLS cap wrench designed to fit the fl-820, i dunno know the part # but ill check tomorrow it fits with a 3/8 drive ratchet, i use it to break all of the 4.6 filters (sohc, dohc, car or truck) it just makes life easier i dont have time to let the car cool off. i can even get the filter out with the cap wrench still on itDominus said:No room for the type of filter wrench that goes on the head.
Dominus said:It's not like I'd be the first street car to have that much oil in the system. It takes about 30-40 seconds longer than stock for the oil to reach temperature, but it doesn't bother me. I'm not THAT much of a leadfoot.
Why do it? Damn clean oil, no starvation, and it stays that way for a long time. I've never had to change my oil because it got too dirty. Always because the damn additives package starts fading away (the factory oil additives. I don't subscribe to external additives) Of course that figure is going to go up again when I install my Ponyfreak oil pan.
5.5 quarts? No way in hell. Contrary to an earlier comment, my heads are spotless under the covers, and it took 7 quarts. I never had the chance to measure it with this car, but it seems it was about the same, as the total amount of oil required was similar.
Dr. Paul said:Do you have a super-powerful racecar Lincoln or something?
Dr. Paul said:Ford says 6 qts +/- .25 quarts.
I don't know where everyone is getting 7 quarts. Hooray for excessive windage and foaming oil!
Dominus said:Seeing as the dipstick measures the oil level, rather than the oil volume, that will not be a problem. Only a rise in the oil level could cause such issues, and the oil level is where it is, regardless of the volume.
Dr. Paul said:Too much oil = lose hp
Too much oil = foamy oil
Too much oil = excessive windage
