I have seen a few people asking about a how-to for the degas bottle (coolant reservoir) replacement lately. I haven't seen a write up myself so I had some free time and figured I would make one up. This is not a difficult job at all, it took me around an hour or so with bleeding the cooling system. I hope this helps some people.
1) Drain the cooling system according to the tech article
How to Drain the Lincoln LS Cooling System
2) Remove the windshield wiper arms. Pull off the rubber cap and remove the nuts. Pull up and down gently on the arm until it comes off. You may want to mark the position of the arm before you remove it so you can replace it in the exact same position.
3) Remove the pin clips that hold the cowl covers on. Push in on the center and they will come out. Remove both cowl covers
4) Remove the 7 bolts holding the strut tower/firewall brace and remove the brace
5) Remove the 2 bolts and 2 hoses on top from the degas bottle. Leave the bottom hose attached to the degas bottle
6) Remove the pinch clamp on the lower hose from the heater core pipe located behind the drivers side valve cover. I would throw this clamp in the trash and use a regular wormgear hose clamp. The factory clamp is hard to put back on considering its location
7) Install the lower hose on the new degas bottle in the same position as the old bottle
8) Install the new degas bottle and connect the lower hose to the heater core using a worm gear hose clamp to make it easy
9) Re-install the 2 degas bottle bolts, 2 upper hoses, strut tower brace, cowl covers and wiper arms
10) Fill and bleed the cooling system according to the tech article referred to in step 1 and you are done
