G-RELL
FULLY DIPPED LS
LOL i was the 2nd visitor to his page... Welcome back?!??!
or
...there's a glitch in the Matrix
or
I lurk and glean plenty of good info without having to post superfluous redundant info. Ive fixed the ball joints wheel bearings and plenty of other things thanks to the support on this forum. This problem is a real pain that I need some help with. Just to rant, the design of the cooling system is terrible; poor design which is too complicated and uses inferior plastic parts -- enough said. Now onto fix it^ wow member since '04 and this is your first post???
... without having to post superfluous redundant info. ....
Still over heating without much change. I'm down to two possible causes, the hydraulic fan or the thermostat. Is there any way to tell if the fan is not kicking into high?
Well guys, looks like it is worst case scenario.
The place that replaced all the coolant parts has tested everything and couldn't find anything.
So they did a block test and it looks like a blown headgasket...sh*t.
So now I have to figure out what to do since that's going to be expensive to fix relative to the value of the car.
so would a small air leak cause the symptoms I have?
driving <10 miles, a/c on 60, no problem.
Right around the 10 mile mark the temp creeps up.
I need to find the full report, but I know for sure they replaced the thermostat housing and the thermostat, and the thermostat housing cap.
Not sure if any hoses were replaced.
I know the degas bottle and cap were not replaced.
philly0420 said:don't know a whole lot about 3.9 and I don't wanna know. Too many problems.
The degas bottle develops hairline cracks not allowing the system to pressurize. Have you noticed any fluid on the ground behind the driver's wheel?
There's nothing wrong with the engine. It's just the plastic parts get brittle over time/heat cycles.
And tensioners that are plastic and the tendency to chuck coils and the gen1 fan abortion. Really Ford should have just used the 4.6 instead of some destroked jag bullchit. I can deal with the marks poorly designed bullchit but the ls is too much.
