I guess Christmas has arrived. Tasca came throught in a big way after that initial let-down. Got an email - processed 4pm yesterday, next-day air - arrived from RI to MN 1:30 today, very nice indeed. (just a note, the two thicker o-rings pictured . . only need one as 04 SPORT confirmed, but I'd added it to the order just before knowing for certain). Only thing missing is the radiator; with upper rad. support bracket off, visually ok (we'll see).
front of the plastic side tank on the passenger side. You may need to remove the upper radiator mount on that side to see it well enough. Here's a picture of the front of the radiator with the surface of concern circled in red.
So far I have plumbing out, plastics (except at back/and degas), Aux., Dccv, connectors etc.
Intake manifold is NOT off and, but for the EGR to EX manifold tube NUT I would be further along. I tried that this evening to complete the disassembly, no such luck. I have a 22mm open-end, too small. What size exactly for the EGR exhaust pipe, rusty looking nut? . . . as if welded (can't say I wasn't warned, and terrific advice, SS, to remove the fuel pressure sensor). I will be stopping tmrw to get the right size wrench as well as a LB-INCH torque wrench.
Other quick question: IN manifold is going to be removed without taking out fuel rails. Is there an easy way to get the fuel line connecting both rails off without chomping up that fuel hose? (it goes over and across the manifold).
Also, not going to remove throttle body, don't know of advantage to that.
THANKS for the help!!!
