EmpireSix
i think mine goes longer than 10 minutes, yet im still to time it
You PASSED
The noises you heard were the solenoids (panels) opening and closing as it did the tests.
If you got a number like 24.4 183 would say something failed and take it to your nearest rip off....I mean dealership and get it looked after.
I have already done that test and it reads: 88.8 -188.8 Does anyone know what this means?
ok i bleed my lincoln because the stat was sticking i did the test( off and floor button sametime and then hit auto. it went 88.8 188.8. started to get some heat but now it reads 12 64 does anybody know what code this is??? thanks girty
12 64 is "Servo Motor Floor Circuit Failure"
12 66 is "A/C Post Heater Sensor is Open"
I don't know what these mean or how to fix but I hope it helps
I just started to have the same problem...BUT....I get plenty of heat/defrost as long as I don't use the blower fan past 1/4 of the way. If I turn up the fan it starts to cool down. Anybody else notice this? I just found this site and I'm going to try some of your sugestions.
keep the cold air, you'll need it in summer so u dont use ur a/c, lol
Does anyone know where i can get or have the part number for the auxiliary pump? I checked the team ford parts website and was unable to locate it. Thanks.
The part # is 1W4Z-18D473-AA Pump ASY.
