Tried the trick with the buttons to get a self diagnostic reading but apperently this does not seem to work on my 2005 LS 6 cylinder so I will do as the stealership does and replace parts untill the system works properly.
Sure it does. The procedure is a little different for gen II.
The DATC module self-test through the front panel display:
* can be initiated at any time. Normal operation of the system stops when the self-test is activated.
* is entered by pressing the OFF and DEFROST buttons simultaneously and then pressing the AUTO button within 2 seconds. Record all DTCs displayed.
* concludes by reporting all on-demand DTCs. Follow the diagnostics procedure given under ACTION in the DTC index for each DTC given.
* reports individual on-demand DTCs as 4-digit DTCs (less the alpha character).
* will calibrate all the mode doors and check all analog inputs. The DATC module will only report on-demand (hard) faults that occurred while the DATC module was conducting its self-test.
* will light all control panel display segments if no faults are detected.
* will report individual on-demand DTCs without the °C symbol lit.
To exit the self-test, press the DEFROST button. This will clear all on-demand codes from the DATC module memory. If no button is pushed, DTCs will continue to be displayed.
Upon exit from the self-test the DATC module returns to operational status. The DATC module executes a hard (cold boot) reset which places the DATC system in the OFF mode.
ontinuous DTCs are fault codes recorded by the DATC module which have occurred during normal operation. For the DATC module this means that all faults (intermittent or hard) that occur while the module is in an operational state shall be reported as a continuous DTC.
* To retrieve continuous DTCs, press the OFF and DEFROST buttons simultaneously, followed by pressing the RECIRC button within 2 seconds.
* The DATC module will report all continuous DTCs to the vacuum fluorescent (VF) display.
* The DATC module will not carry out a self-test; it will only display continuous faults codes which are stored in memory.
* All VF display segments will light if no faults are detected.
* Individual continuous DTCs will be reported with the °C symbol lit.
* DTCs shall be reported as a 4-digit DTC (less the alpha character).
* Pressing the front DEFROST button will exit the retrieve continuous DTCs mode and clear all continuous DTCs from DATC module memory.
* Pressing any other button (other than DEFROST) will exit the retrieve continuous DTCs mode and maintain all continuous DTCs in DATC module memory.
* Upon exit from the retrieve continuous DTCs mode the DATC module returns to operational status. The DATC module executes a hard (cold boot) reset which places the DATC system in the OFF mode.
