hite337
Hite Performance
I know this is a somewhat Gen1 centric thread, but if the Gen2 is *NOT* PCM controlled and using a simpler internal regulator then fabricating a bracket to bolt on a 3G/4G alternator and swapping over a wiring harness would be the solution there. Just need to find an alternator with a relatively compatible size and layout.
I know that DB Electrical make a HO alternator for the gen2 and if they are not PCM controlled then it SHOULD be a simple bolt on mod. If anyone with a gen2 has a HO alternator installed with no issues then please chime in to clear that up for the gen2 guys.
