ONEBADMK8
You could get a bigger core in there easily. At least it looks like it Mike?
Laser, here is how the lower will bolt up to the heads.
Mike
Thanks Mike, thats what I figured. So the question stands, how to bolt it in place and have the intercooler seal itself from the outside world?
Sounds like you need to wait till things are figured out.So when all parts are made how much will all this cost,
+1..........Sounds like you need to wait till things are figured out.
I still want one. If I have to have a port front and rear drilled to hold a meth nozzel then thats cool. A chemical intercooler would work excellent if it can be sprayed directly under the blower and cover as much area as possiable. I think two small nozzels would work well placed front/rear.
My goal when starting this thing, was to bolt an Eaton onto B-heads with little to no fabrication and as little expense as possible. I am aiming for 375-400 Horsepower and a FLAT torque curve which will make the car MUCH more fun to drive. The guys who want more than that will need to think about C-heads and the supporting hardware. The average MarkVIII can't handle much more than 400 HP without suspension and body reinforcements so I figure this kit will be a daily driver friendly setup.
Bingo.
A lot of guys would be happy picking up a used Eaton and slapping it on. What more do you need for a daily driver or weekend warrior really?
My only request is that you consider leaving some extra room for a 2nd boss for either another injector or as a nitrous port. That's all it would take to make me happy.![]()
