Pretty high, try it out!
hellyeaz pass it over to me
Don't assume his problem is the same as yours.
He has a miss....yours seems to be a stumble.
Completely different.
FWIW I have platinum plus 4 in my mark for 15.000 miles now and it is smooth as glass-Plugs fire or don't, and if that were your problem I would have to think you'd get a code.
well the problem is getting worse now when i give it gas in park RPMs drop about 100 to 200 RPMs before going up, and in drive when i give it gas it really starts chugging and jerking and feels like its about to die WTF!!!!!!!! and it sounds like me and camel have the same problem
Mines a stumble and a miss....It stumbles and when I hammer on the gas it hesitates.
Jamie thinks it's because my IMRC's are broke because I have a code that says they are stuck open and he cleaned them by hand and they're still not working right. So being that the IMRC controller is obsolete I'm pretty much f'd on that.
I was thinking about getting deletes, but I was told you need to have someone program your computer for them to be deleted properly...My tuner can't even delete my O2 sensors....SCT themselves can't even figure it out.
I don't doubt Jamie for one second, I have seen Fords do some screwy things and the cause be a part not even related to the issue but I wouldn't think the IMRC would cause a miss and or a stumble. I think you have a flaky PCM or harness somewhere. Why? Even with the IMRC stuck open you'd be a dog off the line but it shouldn't miss and stumble when you get on the gas. I think that the PCM also disables the IMRC system if there's a fault seen. I also think that it enables it once the PCM sees that the IMRC is in the closed position when it should be closed after 2 drive cycles, I think. Also with the O2 sensors, just about any tuning program should turn the sensors off or so I thought. To narrow it down a bit, with the stumbling and missing AND the IMRC reporting being stuck open, I'd go with harness or ground being broken or shorted somewhere. However the issue with the O2 sensors known, I'd go with a PCM. You might borrow a PCM from wherever and see if that takes care of the issue. This of course is my own theory and not necessarily fact
till it sucks the porcelain into the cyl, you've been warned
Have you done anything to it yet?
i havent even been driving it. its just been sitting there doing nothing. now reading further down could my problem possible be a bad computer? im kinda at my wits end here
put the stock coils back on.
go to the pull a part or a local salvage yard and get a set for less than $50 probablyyeah bout that kinda throw em away. oops there another $100+
Ripped's issue may be a bad PCM...I am quite sure yours is related to coil/plugs. Take a chance on buying a $30 set of Motorcraft or Autolite platinum plugs and put the stock coils back on.
:shifty:for motorcraft plugs witch do i want copper or platinum
:shifty::shifty:
Now you have been warned twice.Ok, years and 15,000+ miles later, I've "been warned"
