Trippen Out
So i guess ill have to call the shop to find out what really happened. on my paper work it just says wheel alignment 89.99 and 15 hours of suspenion labor in edition to that billed at 10.50 an hour. anyway here are the alignment before and after specs. they aligned it twice
left front ---------------- right front
camber 0.04 ---------------- camber -1.7
caster 4.5 ---------------- caster 7.2
toe -0.69 --------------- toe -0.49
left rear ---------------- right rear
camber -1.8 ---------------- camber -2.4
toe -0.23 ---------------- toe 0.12
front
total toe -1.17
steer ahead -0.10
rear
total toe -0.11
thrust angle -0.18
Then after the first attempt
camber -0.04 ---------------- camber -0.6
caster 6.1 ---------------- caster 6.2
toe -0.00 --------------- toe -0.05
camber -1.8 ---------------- camber -2.5
toe 0.21 ---------------- toe -0.04
front
total toe 0.05
steer ahead -0.02
rear
total toe 0.17
thrust angle 0.12
Then after this they broke down the front end and started over after fixing whatever was wrong mostly tie rod related and the steering wheel being 180 off as well.
the 2nd before attempt
camber -0.06 ---------------- camber -0.9
caster 5.5 ---------------- caster 5.4
toe -0.35 --------------- toe -0.66
camber -1.9 ---------------- camber -2.5
toe 0.05 ---------------- toe 0.02
front
total toe -1.01
steer ahead 0.16
rear
total toe 0.07
thrust angle 0.01
and then the final time result
camber -.07 ---------------- camber -1.0
toe 0.10 --------------- toe 0.11
camber -1.9 ---------------- camber -2.6
toe 0.06 ---------------- toe 0.03
front
total toe 0.21
steer ahead 0.00
rear
total toe 0.09
thrust angle 0.01
front
total toe -1.17
steer ahead -0.10
rear
total toe -0.11
thrust angle -0.18
front
total toe 0.05
steer ahead -0.02
rear
total toe 0.17
thrust angle 0.12
front
total toe -1.01
steer ahead 0.16
rear
total toe 0.07
thrust angle 0.01
front
total toe 0.21
steer ahead 0.00
rear
total toe 0.09
thrust angle 0.01
