Today's Daily special (August 15, 2009) is Gilmour Flexogen 8 ply Hose.
Regular Price for 50 feet is $34.99. Today's price is $26.34!
Today's Daily special (August 16, 2009) is Dodo Juice Diamond White Hard Wax.
Regular Price for 250 ml is $69.99. Today's price is $54.72!
Regular Price for 30 ml is $13.99. Today's price is $10.55!
  • The Dodo Juice Diamond White hard carnauba wax is designed to work exceptionally well on lighter colored vehicles
  • Extremely easy to apply and remove, especially when applied in thin layers
  • Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
  • Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
  • Apply with a foam applicator pad and remove with a plush microfiber towel
Today's Daily special (August 17, 2009) is Lake Country Black Finishing Pad.
Regular Price for 6.5" is $9.99. Today's price is $7.49!
  • A finishing pad, designed to bring the paint to its maximum depth and gloss with a finishing polish
  • Also can be used to apply a paint cleaner, glaze or sealant
  • Menzerna PO85RD is one of the most popular polishes to use with a black finishing pad
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (August 18, 2009) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.49!
  • Foam based formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry microfiber towel
  • For optimal results, give a final wipe down with the low nap, glass microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Today's Daily special (August 19, 2009) is Lake Country Ulti-Mit.
Regular Price is $15.99. Today's price is $11.99!
  • A paint safe foam wash mitt that has two different surfaces to tackle various areas of your vehicle
  • Holds large amounts of suds and water which helps minimize marring the paints finish
  • Use the red cubed side to wash your paint, as it is the softer of the two sides
  • Use the black side to clean stubborn contamination off of lower panels, tires, wheel wells and more
  • Highly recommended to be used with a Grit Guard insert to easily release contamination
  • Will outlast natural fiber mitts due to the durable foam design
Today's Daily special (August 20, 2009) is Optimum (OPT) Tire Shine.
Regular Price for 17 oz is $11.99. Today's price is $8.99!
Regular Price for 128 oz is $35.99. Today's price is $26.99!
  • Water based tire dressing that applies easily and does not sling onto your paint
  • Can be applied in multiple layers for a glossier look or buffed down to a matte finish
  • We recommend using a Lake Country tire dressing applicator to apply Tire Shine
Today's Daily special (August 24, 2009) is Chemical Guys M-Seal Pure Sealant.
Regular Price for 16 oz is $19.99. Today's price is $14.99!
  • One of the best bang for the buck, pure sealants for under $20
  • Easy to apply and remove when applied properly, which is as thin as possible
  • M-Seal not only protects your paint, but leaves behind a great shine and sharp reflections
  • Best applied with a foam applicator pad and removed with a microfiber towel
  • When using a buffer, best applied with a blue fine finishing pad
Today's Daily special (August 25, 2009) is Poorboy's World Super Swirl Remover 2.5 (SSR 2.5).
Regular Price for 16 oz is $15.99. Today's price is $11.99!
  • Designed to remove a majority of imperfections in the clear coat
  • Removes moderate to deep swirls, oxidation, water spots, scratches and other imperfections
  • Can be applied in either the shade or in the sun, making the polishes great for mobile detailers
  • Poorboy's SSR 2.5 should be followed up with a finishing polish for maximum results
  • Works best when applied with a quality buffer, such as a Porter Cable 7424 or Flex XC3401VRG
  • When using a buffer, best applied with an orange light cutting pad
  • For accurate product dispensing, we recommend using a 4oz dispenser bottle or 8oz yorker bottle
Today's Daily special (August 26, 2009) is Poorboy's World Spray & Wipe (S&W).
Regular Price for 16 oz is $8.99. Today's price is $6.74!
Regular Price for 32 oz is $14.99. Today's price is $11.24!
Regular Price for 128 oz is $32.99. Today's price is $26.10!
  • Extremely versatile product that is a favorite amongst professional detailers
  • Quick and easy waterless wash product for lightly contaminated vehicles
  • Excellent clay bar lubricant, even diluted at a 1:1 ratio with distilled water
  • Perfect product to keep in your glove compartment to clean up emergency bird bombs, sap, tar, etc.
  • Best applied with a plush microfiber towel to minimize any micro-marring in the paint
  • For maximum efficiency and convenient storage use in a 4oz pump spray bottle
Today's Daily special (August 27, 2009) is P21S Concours Carnauba Wax.
Regular Price for 6.2 oz is $31.99. Today's price is $26.05!
  • Very easy to apply and remove carnauba wax that looks great on any color vehicle
  • Includes an applicator pad that conveniently stores inside the top of the wax
  • Unlike other waxes, P21S Concours Carnauba wax will not stain your trim
  • Excess product should be removed with a quality microfiber towel
  • P21S recommends prepping the surface with Paintwork Cleanser for best results
Today's Daily special (August 29, 2009) is Menzerna Final Polish II (FPII).
Regular Price for 16 oz is $18.99. Today's price is $14.42!
Regular Price for 32 oz is $29.99. Today's price is $22.49!
  • A great finishing polish, designed to remove hazing, holograms and light surface imperfections
  • Restores depth and gloss to the paints finish and is easy to work with
  • Easy to remove when worked into the paint properly
  • Recommended application is using a buffer with a white polishing pad
Today's Daily special (August 30, 2009) is Clear Kote Red Moose Machine Glaze.
Regular Price for 16 oz is $17.99. Today's price is $13.49!
  • Enhance the gloss and depth of any color paint, while hiding minor imperfections
  • We recommend applying a carnauba wax on top of Red Moose Glaze
  • To avoid bonding issues, we do not recommend applying a sealant on top of Red Moose Glaze
  • We recommend using a foam applicator pad along with some elbow grease for application
  • Remove Red Moose Glaze with a quality microfiber towel
Today's Daily special (August 31, 2009) is 303 Aerospace Protectant.
Regular Price for 16 oz is $12.99. Today's price is $9.74!
Regular Price for 32 oz is $22.99. Today's price is $17.24!
Regular Price for 128 oz is $54.99. Today's price is $41.24!
  • Strong UV protection on vinyl, rubber, leather and plastic
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Treated surfaces resist dust, soiling, staining and also repel water
  • Most commonly used on interior dashboards, center consoles, door trim, and leather seats
  • Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
  • For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
Today's Daily special (September 3, 2009) is Chemical Guys Fabric Clean.
Regular Price for 16 oz is $6.99. Today's price is $5.24!
  • Powerful concentrated fabric cleaner and deodorizer that works wonders on carpet and upholstery
  • Dilute down to an 8:1 ratio with distilled water, or use full strength for stubborn stains
  • We recommend using a brush to agitate stubborn stains in fabric and carpets
  • For easy dilution and usability, we recommend a 22 oz spray bottle
Today's Daily special (September 4, 2009) is Plexus Plastic Polish, Cleaner & Protectant.
Regular Price for 13 oz is $17.99. Today's price is $14.49!
  • Clean, polish and protect all of your plastic surfaces, leaving behind anti-static properties
  • Ideal for clear plastics, such as gauges, headlights, tail lights, clear bras and plastic windows
  • For best application, apply to a plush microfiber towel, then gently wipe the plastic
Today's Daily special (September 5, 2009) is Chemical Guys Hose Free Eco Wash.
  • Perfect for mobile detailers, enthusiasts without access to a hose or washing in a garage
  • All you need is to fill up 2 buckets of water and you can wash your car, no water source needed
  • Best applied with a plush microfiber towel, grout sponge or sheepskin wash mitt
  • Environmentally friendly
Today's Daily special (September 6, 2009) is Poorboy's World Spray & Rinse.
Regular Price for 32 oz is $15.99. Today's price is $11.99!
  • Powerful, acidic wheel cleaner designed to work best on alloy, clear coated wheels
  • Dilute down to a 6:1 ratio for regular maintenance, use a stronger concentration as needed
  • Works best when an E-Z Detail Brush is used in conjunction with PBW Spray & Rinse
  • Protect your just cleaned wheels with Poorboy's World Wheel Sealant for easy maintenance
Today's Daily special (September 7, 2009) is Chemical Guys Wheel & Rim Citrus Cleaner.
  • Citrus based wheel cleaner that is safe to use on virtually any wheel surface
  • Concentrated solution makes this a great value as you can dilute it down 7:1 with water
  • Works best when an E-Z Detail Brush is used in conjunction with Wheel & Rim Citrus Cleaner
Today's Daily special (September 8, 2009) is Chemical Guys Citrus Wash and Clear.
Regular Price for 128 oz is $24.99. Today's price is $19.00!
  • One of our most versatile shampoos that can strip off previous coats of protection or maintain it
  • A great sudsing shampoo makes it a hit in foam guns, great lubricity and powerful cleaners
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Today's Daily special (September 9, 2009) is Lake Country 4 Inch Orange Light Cutting Pad.
Regular Price for 4" is $4.99. Today's price is $3.74!
  • A light cutting pad designed to remove moderate swirls and scratches with an abrasive polish
  • Menzerna Super Intensive Polish (SIP) is one of the most popular products to use with an orange pad
Today's Daily special (September 11, 2009) is Poorboy's World Spray & Gloss (S&G).
  • Best used after a wash to increase the depth and gloss of any color paint
  • Helps extend the protection of sealants and waxes
  • Easy to apply and remove without streaking when applied correctly
  • Not only works well on paint, but glass, chrome and other areas of your vehicle.
Today's Daily special (September 12, 2009) is Menzerna High Gloss Acrylic Shield (HGAS).
Regular Price for 32 oz is $27.99. Today's price is $21.26!
  • An outstanding spray on sealant that enhances depth and gloss and extends your paints protection
  • Specifically formulated to work best with Menzerna FMJ paint sealant
  • Most commonly used after washing and drying your vehicle as a maintenance product
Today's Daily special (September 13, 2009) is Dodo Juice Double Wax Kit.
Regular Price for 2 x 200 ml is $159.99. Today's price is $133.19!
  • A combination of a Dodo Juice hard and soft wax for the best of both worlds
  • Apply a coat of the hard wax for a base and longer durability for your protection
  • Top the hard coat with a layer or more of the soft wax for additional depth and gloss
  • For maximum results, allow for 12 - 24 hours between coats
Today's Daily special (September 14, 2009) is Menzerna Top Inspection Spray.
Regular Price for 500 ml is $19.99. Today's price is $14.99!
  • Remove excess polish and polishing oils with Menzerna Top Inspection Spray
  • Use like you would a quick detailer, typically misting into a quality microfiber towel then wiping
