Today's Daily special (October 18, 2009) is Menzerna PO85RD Polish.
Regular Price for 32 oz is $39.99. Today's price is $29.99!
  • When you want the absolute maximum depth and gloss, finish your polishing with PO85RD
  • Works best after correcting paint imperfections with more aggressive polishes
  • Easy to work with, with long work times and easy removal when properly broken down
  • Most commonly applied with a black or blue finishing pad when used on a buffer
Today's Daily special (October 19, 2009) is Optimum (OPT) No Rinse (ONR).
Regular Price for 32 oz is $15.99. Today's price is $12.15!
Regular Price for 128 oz is $39.99. Today's price is $31.81!
Regular Price for 8 oz is $7.99. Today's price is $5.99!
  • One of the must haves for any auto detailing enthusiast or professional, simply revolutionary
  • ONR is perfect for mobile detailers, enthusiasts without access to a hose or washing in a garage
  • All you need is to fill up 2 buckets of water and you can wash your car, no water source needed
  • Best applied with a plush microfiber towel, grout sponge or sheepskin wash mitt
Today's Daily special (October 20, 2009) is Clay Magic Fine Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $20.80!
  • Fine grade clay bar that is one of the standards in the industry for enthusiasts and professionals
  • Remove embedded surface contamination that does not come off during the washing process
  • Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
  • Helps you get the most out of any step you perform after using the clay bar
  • Use with plenty of clay bar lubricant to minimize any micro-marring that may occur
  • We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
Today's Daily special (October 21, 2009) is Lake Country Black Finishing Pad.
Regular Price for 6.5" is $9.99. Today's price is $7.49!
  • A finishing pad, designed to bring the paint to its maximum depth and gloss with a finishing polish
  • Also can be used to apply a paint cleaner, glaze or sealant
  • Menzerna PO85RD is one of the most popular polishes to use with a black finishing pad
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (October 22, 2009) is Chemical Guys Vertua-Bond 408.
Regular Price for 16 oz is $26.99. Today's price is $20.24!
  • Properly preps your paints surface for applying a sealant or wax to your paint
  • Ensure you achieve the maximum durability out of your protection by using Vertua-Bond 408
  • Apply with a foam applicator pad and remove with a clean microfiber towel
Today's Daily special (October 23, 2009) is Optimum (OPT) Tire Shine.
Regular Price for 17 oz is $11.99. Today's price is $8.99!
Regular Price for 128 oz is $35.99. Today's price is $26.99!
  • Water based tire dressing that applies easily and does not sling onto your paint
  • Can be applied in multiple layers for a glossier look or buffed down to a matte finish
  • We recommend using a Lake Country tire dressing applicator to apply Tire Shine
Today's Daily special (October 24, 2009) is 303 Fabric & Vinyl Cleaner.
Regular Price for 32 oz is $14.99. Today's price is $11.24!
Regular Price for 128 oz is $39.99. Today's price is $29.99!
  • Cleans carpets, upholstery, vinyl, rubber, leather, plastic and much more
  • Safely removes oil, grease, ink, coffee, tea, wine, juice, blood, and tons more
  • Powerful concentrated formula makes for a great value
  • Dilute up to a 30:1 ratio! That's only $0.01 per ounce of cleaning solution (from 128 oz size)
  • Works in carpet extractors
  • Maximum cleaning ability is achieved when used with warm water
  • Best results achieved when agitated with a brush or damp towel
  • Dilute into a 22oz empty spray bottle or a handy 4oz pump spray bottle
Today's Daily special (October 25, 2009) is Chemical Guys Window Clean.
Regular Price for 16 oz is $5.99. Today's price is $4.49!
  • A tint safe window cleaner that cuts through grime and leaves windows streak free
  • Best applied with a microfiber towel and followed up with a glass microfiber towel
Today's Daily special (October 26, 2009) is Poorboy & World Spray & Rinse.
Regular Price for 32 oz is $15.99. Today's price is $11.99!
  • Powerful, acidic wheel cleaner designed to work best on alloy, clear coated wheels
  • Dilute down to a 6:1 ratio for regular maintenance, use a stronger concentration as needed
  • Works best when an E-Z Detail Brush is used in conjunction with PBW Spray & Rinse
  • For easy dilution and usability, we recommend a 22 oz spray bottle
  • Protect your just cleaned wheels with Poorboy's World Wheel Sealant for easy maintenance
Today's Daily special (October 27, 2009) is Poorboy's World Leather Stuff.
Regular Price for 16 oz is $17.99. Today's price is $13.49!
  • An amazing one step solution for leather. Cleans, lightly conditions, and UV protects!
  • Restores and leaves behind a pleasant leather scent
  • Easy to apply and remove, while leaving behind a like new matte finish
  • Also works well on vinyl and rubber surfaces throughout the vehicle and home
  • Best applied with a terry cloth applicator and wiped to desired finish with a microfiber towel
Here is a must read article for anyone polishing their paint. If you think the M105 and M205 may just be hype I encourage you to read this article. Our detailing expert, Todd from Esoteric Auto Detail, just completed a full review of the M105 and M205 for both orbital and rotary buffers. It explains more about each product, how they work, how to get optimal results and detailed instructions with some pictures. If you have any questions please let me know.
Greg @ DI
Today's Daily special (October 28, 2009) is Optimum (OPT) Opti-Bond Tire Gel.
Regular Price for 128 oz is $35.99. Today's price is $27.81!
  • Gel based tires dressing that applies easily and does not sling onto your paint
Today's Daily special (October 29, 2009) is Klasse All In One (AIO).
Regular Price for 500 ml is $27.99. Today's price is $21.28!
Regular Price for 1000 ml is $39.99. Today's price is $30.40!
  • A must have for anyone looking for an all in one (AIO) product that cleans and protects
  • A strong chemical cleaner that can remove oxidation, water spots, and other surface imperfections
  • Leaves behind an acrylic layer of protection that lasts months
  • Easy to apply and remove when applied properly, which is as thin as possible
  • Can be applied with a foam applicator pad and removed with a quality microfiber towel
  • When using a buffer, best applied with a white polishing pad or black finishing pad
Today's Daily special (October 30, 2009) is Menzerna Finishing Touch Glaze (FTG).
Regular Price for 16 oz is $18.99. Today's price is $14.42!
Regular Price for 32 oz is $23.99. Today's price is $17.27!
  • A glaze that utilizes kaolin clay and oil fillers to help improve the depth and gloss of your paint
  • Can mask minor surface imperfections in the paint
  • Most commonly applied with a black finishing pad when used on a buffer
Today's Daily special (October 31, 2009) is Clear Kote Red Moose Machine Glaze.
Regular Price for 16 oz is $17.99. Today's price is $13.13!
  • Enhance the gloss and depth of any color paint, while hiding minor imperfections
  • We recommend applying a carnauba wax on top of Red Moose Glaze
  • To avoid bonding issues, we do not recommend applying a sealant on top of Red Moose Glaze
  • We recommend using a foam applicator pad along with some elbow grease for application
  • Remove Red Moose Glaze with a quality microfiber towel
Today's Daily special (November 1, 2009) is Chemical Guys Grime Reaper.
Regular Price for 16 oz is $7.99. Today's price is $5.91!
Regular Price for 128 oz is $24.99. Today's price is $17.74!
  • One of our most powerful degreasers available, designed to easily cut through contamination
  • Powerful concentrated solution can be diluted down 8:1 with water and still maintain effectiveness
  • Perfect to degrease wheel wells, engine bays, door jambs, tires and much more
Today's Daily special (November 2, 2009) is Lake Country 4 Inch Orange Light Cutting Pad.
Regular Price for 4" is $4.99. Today's price is $3.59!
  • A light cutting pad designed to remove moderate swirls and scratches with an abrasive polish
  • Menzerna Super Intensive Polish (SIP) is one of the most popular products to use with an orange pad
Today's Daily special (November 3, 2009) is Poorboy's World Quick Detailer Plus (QD+).
Regular Price for 16 oz is $12.99. Today's price is $9.22!
  • A great quick detailer to be used on top of any sealant or wax for added depth and gloss
  • A perfect maintenance product to use after a wash to help prolong your coat(s) of protection
  • Easy to apply and remove without streaking when applied correctly
  • Best applied with a plush microfiber towel to minimize any micro-marring in the paint
  • For convenient storage and easy, even application, we recommend using a 4oz pump spray bottle
Today's Daily special (November 4, 2009) is Poorboy's World Super Swirl Remover 1 (SSR 1).
Regular Price for 16 oz is $15.99. Today's price is $11.67!
  • Designed to remove light surface imperfections and improve the depth and gloss of the paint
  • Removes light swirls, oxidation, water spots, light surface scratches and other minor imperfections
  • Can be applied in either the shade or in the sun, making the polishes great for mobile detailers
  • Works best when applied with a quality buffer, such as a Porter Cable 7424 or Flex XC3401VRG
  • When using a buffer, best applied with a white polishing pad or black fine finishing pad
  • For accurate product dispensing, we recommend using a 4oz dispenser bottle or 8oz yorker bottle
Today's Daily special (November 5, 2009) is Lake Country Tire Dressing Applicator.
Regular Price is $1.99. Today's price is $1.48!
  • A perfect applicator pad to apply your favorite tire dressing
  • Firm foam design that will not shred like cheaper tire dressing applicator pads
  • Works excellent with Poorboy's Bold 'n Bright water based tire dressing
Today's Daily special (November 6, 2009) is Poorboy's World Bug Squash.
Regular Price for 16 oz is $10.99. Today's price is $7.80!
Regular Price for 32 oz is $15.99. Today's price is $11.83!
  • Paint safe, pre-wash degreaser designed to break up stubborn contamination prior to washing
  • Helps loosen bug splatter, tar, sap, bird droppings, and other forms of contamination
  • Concentrated solution which should be diluted down to a 3:1 ratio with distilled water
  • Remember to protect the areas you use Bug Squash on with a sealant or wax
  • For easy dilution and usability, we recommend a 22 oz spray bottle or a convenient 4 oz pump bottle
Today's Daily special (November 7, 2009) is Chemical Guys Microfiber Cleaning Detergent.
Regular Price for 16 oz is $8.99. Today's price is $6.70!
  • Restore your microfiber to a like new condition every wash
  • Helps extend the life of your microfiber towels by keeping them fresher longer
  • Works great with any microfiber product: towel, applicator, mitt, etc.
Today's Daily special (November 8, 2009) is Meguiar's Quik Interior Detailer.
Regular Price for 16 oz is $6.99. Today's price is $5.17!
  • Clean and protect plastics, vinyl, leather, rubber, metal, gauges, audio equipment and more
  • The one interior quick detailer you'll need to keep your car looking and smelling fresh
  • Best applied with a quality microfiber towel
  • Pick up a 4 oz pump spray bottle to easily store this in your glove compartment for emergency clean ups
Today's Daily special (November 9, 2009) is Optimum (OPT) Protectant Plus.
Regular Price for 17 oz is $11.99. Today's price is $8.93!
Regular Price for 128 oz is $35.99. Today's price is $25.55!
  • A versatile product that cleans and UV protects vinyl, rubber, leather, and plastic
  • A perfect one step product to clean your interior dash and console
  • To avoid over spray, we recommend misting Protectant Plus into a towel, then wiping the surface
Today's Daily special (November 11, 2009) is Chemical Guys 50/50 Limited Series Concourse Paste Wax.
Regular Price for 16 oz is $59.99. Today's price is $46.11!
  • Bang for the buck, one of the best carnauba waxes we offer considering you get 16oz of product
  • Offers outstanding depth and gloss as well as sharp reflections
  • Works great on any colored vehicle, light, dark, metallic or non-metallic
  • Best applied with a foam applicator pad and removed with a microfiber towel
