Today's Daily special (September 15, 2009) is Clear Kote Carnauba Moose Wax.
Regular Price for 16 oz is $18.99. Today's price is $14.24!
  • Easy to use carnauba wax that is in a non-paste form
  • Leaves behind lots of gloss and depth and provides weeks of protection
  • Can be applied with a buffer using a blue pad
Today's Daily special (September 16, 2009) is Chemical Guys Extreme EZ-Creme Glaze with Acrylic Shine II.
Regular Price for 16 oz is $16.99. Today's price is $12.74!
  • Enhance the gloss and depth of any color paint, while hiding minor imperfections
  • Properly preps your paints surface for sealing with the acrylic based glaze
  • Easy to apply and remove when applied properly, which is as thin as possible
  • Best applied with a foam applicator pad and removed with a microfiber towel
  • When using a buffer, best applied with a black finishing pad
Today's Daily special (September 17, 2009) is DI Microfiber reTHICKulous Towel.
Regular Price for 16" x 16" is $7.99. Today's price is $6.05!
  • Thickest, softest, most plush towel we carry.
  • Over 3x thicker than regular microfiber towels.
  • Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent.
Today's Daily special (September 18, 2009) is Dodo Juice Orange Crush Soft Wax.
Regular Price for 250 ml is $69.99. Today's price is $54.72!
Regular Price for 30 ml is $13.99. Today's price is $10.55!
  • A Dodo Juice soft carnauba wax designed to work exceptionally well on warmer colored vehicles
  • Extremely easy to apply and remove, especially when applied in thin layers
  • Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
  • Can be applied with a foam applicator pad or literally with your bare hands
  • Dodo Juice soft waxes offer slightly more depth and gloss over the Dodo Juice hard waxes
  • Remove any Dodo Juice wax with a plush microfiber towel
Today's Daily special (September 19, 2009) is Glass Science Rain Clear.
Regular Price for 5 oz + Bonus is $5.99. Today's price is $4.54!
  • Sheet rain and water off of your glass when you have it protected with Rain Clear Gel
  • Help maximize your visibility when driving in bad weather conditions
  • For a streak free finish, try to apply as thin as possible to your glass, then buff clean
  • Includes a sample of Glass Science Glass Scrub
Today's Daily special (September 20, 2009) is Menzerna Final Polish II (FPII).
Regular Price for 16 oz is $18.99. Today's price is $14.42!
Regular Price for 32 oz is $29.99. Today's price is $22.49!
  • A great finishing polish, designed to remove hazing, holograms and light surface imperfections
  • Restores depth and gloss to the paints finish and is easy to work with
  • Easy to remove when worked into the paint properly
  • Recommended application is using a buffer with a white polishing pad
  • For accurate product dispensing, we recommend using a 4oz dispenser bottle
Today's Daily special (September 22, 2009) is Chemical Guys MetalWax - Ultra Fine Metal Polish & Protection.
Regular Price for 16 oz is $12.99. Today's price is $9.74!
  • Restore your metal surfaces to a brilliant shine and protect the finish all in one step
  • Ideal for polishing wheels, metal and chrome trim, interior metal trim and more
  • We recommend using a foam applicator pad for application
Today's Daily special (September 24, 2009) is P21S Metal Polishing Soap.
Regular Price for 10.5 oz is $9.99. Today's price is $8.28!
  • Cleans, restores, polishes, and protects metal surfaces to a brilliant finish in 1 easy step
  • Includes a sponge applicator pad that conveniently stores itself in the top of the jar
  • Soak supplied sponge in warm water, wring out, swipe across soap, then polish the metal
  • For best results, clean the area prior to polishing with soap and water
  • Remove excess product with a quality microfiber towel
Today's Daily special (September 25, 2009) is Menzerna Super Intensive Polish PO83.
Regular Price for 32 oz is $44.99. Today's price is $33.74!
  • Our best medium cutting polish that is known to remove moderate imperfections in the clear coat
  • Most noted for its ability to cut well, good work time, easy removal process and great finish
  • On lighter colored vehicles, it is not always necessary to follow up with a finer polish
  • On darker colored vehicles, we recommend following up with a finer polish, such as PO106FF
  • Most commonly applied with an orange light cutting pad when using a buffer
Today's Daily special (September 29, 2009) is Gilmour Flexogen 8 ply Hose.
Regular Price for 50 feet is $34.99. Today's price is $26.34!
  • One of the most durable hoses available with the thick 8 ply construction
  • Minimize kinks that slow down water flow
  • Full LIFETIME Replacement from Gilmour ensures complete satisfaction
Today's Daily special (September 30, 2009) is Clear Kote Quik Shine (QS).
Regular Price for 16 oz is $9.99. Today's price is $7.49!
Regular Price for 32 oz is $16.99. Today's price is $12.74!
  • An amazing quick detailer that not only enhances the gloss and depth but also cleans the paint
  • Ideal for removing a coating of light dusting on your paint or for boosting gloss after a wash
  • Works great as a clay bar lubricant
  • Use a plush microfiber towel to minimize adding imperfections and to prevent streaking
Today's Daily special (October 1, 2009) is Optimum (OPT) Power Clean.
Regular Price for 17 oz is $11.99. Today's price is $8.99!
Regular Price for 128 oz is $35.99. Today's price is $26.99!
  • A versatile degreaser that can be used on a wide variety of surfaces
  • Powerful concentrated formula can be diluted up to a 3:1 ratio for even more value
  • Perfect for degreasing tires, wheel wells, engine bays, stubborn contamination and to clean carpets
Today's Daily special (October 2, 2009) is Black WOW Black WOW.
Regular Price for 4 oz is $24.99. Today's price is $18.74!
  • Restore faded and neglected trim pieces
  • Removes product residue from trim
  • Lasts through multiple washes
  • Only a tiny bit of product is needed, use sparingly
Today's Daily special (October 3, 2009) is Dodo Juice Hard Candy Hard Wax.
Regular Price for 250 ml is $64.99. Today's price is $50.49!
  • A Dodo Juice hard carnauba wax designed to work on any colored vehicle, light or dark
  • Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
  • Apply with a foam applicator pad and remove with a plush microfiber towel
Today's Daily special (October 6, 2009) is P21S Bodywork Conditioning Shampoo.
Regular Price for 500 ml is $9.99. Today's price is $8.28!
  • An excellent, shampoo with high lubricity and gentle cleaners that will not remove your protection
  • Only a cap full of shampoo is needed in a 5 gallon bucket of water
  • The low sudsing formula does not make this a great shampoo for a foam gun
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Today's Daily special (October 8, 2009) is Klasse High Gloss Sealant Glaze (HGSG).
Regular Price for 500 ml is $20.99. Today's price is $15.96!
Regular Price for 1000 ml is $27.99. Today's price is $21.28!
  • One of our longest lasting sealants that looks best after multiple coats
  • Can be finicky to remove, so we recommend wiping on and wiping off, working in small sections
  • Apply with a foam applicator pad and remove with a quality microfiber towel
  • Properly prep the paint with Klasse All In One chemical polish
Today's Daily special (October 9, 2009) is Lake Country Red Foam Applicator Pad.
Regular Price is $2.49. Today's price is $1.87!
  • Our softest and plushest foam applicator pad that has two distinct sides to apply products with
  • Most commonly used for applying last step products (LSPs), such as sealants and waxes
Today's Daily special (October 10, 2009) is Chemical Guys Bare Bones Undercarriage Spray.
Regular Price for 128 oz is $32.99. Today's price is $25.18!
  • One of our best trim dressings that brings out a beautiful black factory finish
  • Ideal for wheel wells, under carriage, engine bay and any other dark trim pieces
  • To avoid over spray, we recommend misting Bare Bones into a towel, then wiping the trim piece
Today's Daily special (October 11, 2009) is Menzerna PO106FA Nano Polish (Super Finish).
Regular Price for 16 oz is $26.99. Today's price is $20.82!
Regular Price for 32 oz is $49.99. Today's price is $37.49!
Regular Price for 128 oz is $149.99. Today's price is $123.00!
  • Our best selling finishing polish that removes light imperfections and lots of depth and gloss
  • Easy to work with, with long work times and easy removal when properly broken down
  • Most commonly applied with a white polishing pad for a great combination of cut and gloss
  • Can also be applied with a black or blue finishing pad for additional depth and gloss but less cut
Today's Daily special (October 12, 2009) is Lake Country White Polishing Pad.
Regular Price for 6.5" is $9.99. Today's price is $7.49!
  • A polishing pad designed to remove minor surface imperfections with an abrasive polish on a buffer
  • Menzerna PO106FF polish is one of the most popular products to use with the white pad
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (October 13, 2009) is Squash Air Giga Vent Clip Air Freshener.
Regular Price is $9.99. Today's price is $7.49!
  • A fresh, unique smelling air freshener that keeps your car smelling great for weeks
  • Attaches to one of your vents for a fresh scent every time you turn on your heat or air
  • JDM squash scented air freshener
Today's Daily special (October 14, 2009) is Leatherique Rejuvenator Oil.
Regular Price for 16 oz is $29.99. Today's price is $22.69!
  • Detailed Image's best leather care product to restore neglected, faded, hardened leather
  • Restores oils and proteins that are naturally found in leather for a soft and supple feel
  • Works best when allowed to penetrate leather for up to 48 hours, ideally in the heat
  • Using a hair drier to heat up the leather surface allows for maximum penetration and best results
  • Apply Rejuvenator Oil by massaging the product into the leather with your bare hands
  • Must be removed by following up with Leatherique Prestine Clean
Today's Daily special (October 15, 2009) is Menzerna Power Gloss.
  • One of our most aggressive compounds we have to offer, allowing for deep paint correction
  • Most commonly used on a yellow cutting pad or purple foamed wool pad
  • Will leave behind marring and hazing, so it is important to follow up with a less aggressive polish
Today's Daily special (October 16, 2009) is Dodo Juice Time to Dry Drying Detailer.
Regular Price for 250 ml is $12.99. Today's price is $9.74!
  • Dry your paint faster and more effectively
  • Helps minimize adding imperfections during wipe downs
  • Reduce potential water spots on your paint
  • Best used in conjunction with a waffle weave drying towel
Today's Daily special (October 17, 2009) is P21S Concours Carnauba Wax.
Regular Price for 6.2 oz is $31.99. Today's price is $26.05!
  • Very easy to apply and remove carnauba wax that looks great on any color vehicle
  • Includes an applicator pad that conveniently stores inside the top of the wax
  • Unlike other waxes, P21S Concours Carnauba wax will not stain your trim
  • Excess product should be removed with a quality microfiber towel
  • P21S recommends prepping the surface with Paintwork Cleanser for best results
