Today's Daily special (November 12, 2009) is Chemical Guys Fabric Clean.
Regular Price for 16 oz is $6.99. Today's price is $4.96!
  • Powerful concentrated fabric cleaner and deodorizer that works wonders on carpet and upholstery
  • Dilute down to an 8:1 ratio with distilled water, or use full strength for stubborn stains
  • We recommend using a brush to agitate stubborn stains in fabric and carpets
  • For easy dilution and usability, we recommend a 22 oz spray bottle
Today's Daily special (November 13, 2009) is Clear Kote Fine Grade Clay Bar.
Regular Price for 200 g is $26.99. Today's price is $21.90!
  • Remove embedded surface contamination that does not come off during the washing process
  • Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
  • Helps you get the most out of any step you perform after using the clay bar
  • Use with plenty of clay bar lubricant to minimize any micro-marring that may occur
  • We recommend using Clear Kote Quik Shine as a clay bar lubricant and quick detailer
Today's Daily special (November 14, 2009) is Wheel Wax Wheel Wax.
Regular Price for 8 oz is $14.99. Today's price is $12.28!
  • Protects your wheels from stubborn contamination and brake dust build up
  • Easily maintain your protected wheels with automotive shampoo and water
  • Apply Wheel Wax to a clean wheel with a foam applicator pad in thin coats
  • Clean, restore and protect your wheels in one easy step
Today's Daily special (November 15, 2009) is Meguiar's PlastX Clear Plastic Cleaner and Polish.
Regular Price for 10 oz is $7.99. Today's price is $5.83!
  • Ideal for use on headlights, tail lights, motorcycle windshields, convertible windows and much more
  • Restore clarity to clear plastics by removing stains and imperfections
  • Leaves behind a polymer protection for easier maintenance
Today's Daily special (November 16, 2009) is Poorboy's World Spray & Wipe (S&W).
Regular Price for 16 oz is $8.99. Today's price is $6.78!
Regular Price for 32 oz is $14.99. Today's price is $10.79!
Regular Price for 128 oz is $32.99. Today's price is $28.21!
  • Extremely versatile product that is a favorite amongst professional detailers
  • Quick and easy waterless wash product for lightly contaminated vehicles
  • Excellent clay bar lubricant, even diluted at a 1:1 ratio with distilled water
  • Perfect product to keep in your glove compartment to clean up emergency bird bombs, sap, tar, etc.
  • Best applied with a plush microfiber towel to minimize any micro-marring in the paint
  • For maximum efficiency and convenient storage use in a 4oz pump spray bottle
Today's Daily special (November 17, 2009) is Chemical Guys Vertua-Bond 408.
Regular Price for 16 oz is $26.99. Today's price is $20.11!
  • Properly preps your paints surface for applying a sealant or wax to your paint
  • Ensure you achieve the maximum durability out of your protection by using Vertua-Bond 408
  • Apply with a foam applicator pad and remove with a clean microfiber towel
Today's Daily special (November 18, 2009) is Chemical Guys Sofast Odor Eater.
Regular Price for 16 oz is $8.99. Today's price is $6.70!
  • Remove odors from your interior by killing the bacteria causing the foul smell
  • Leaves behind a fresh apple scent that lingers for days
  • To maximize your product, we recommend using a 4oz pump spray bottle to dispense
Today's Daily special (November 19, 2009) is Chemical Guys Go Green! Waterless Wash.
Regular Price for 16 oz is $12.99. Today's price is $9.61!
  • Our most versatile spray on product that cleans, polishes, enhances gloss and protects your paint
  • Use as a waterless wash to remove a light coating of contamination without marring your finish
  • Perfect option to keep in your glove box to clean up bird droppings and other contamination
  • To minimize adding swirls and imperfections, use a plush microfiber towel to wipe and buff
  • To maximize your product, we recommend using a 4oz pump spray bottle to dispense ONE
Today's Daily special (November 20, 2009) is Meguiar's Super Degreaser D108.
Regular Price for 128oz is $13.99. Today's price is $10.21!
  • Works best in engine bays, wheel wells, tires, and other heavily contaminated areas
  • Concentrated formula works effectively even at a 10:1 dilution ratio
  • Allow Super Degreaser to dwell for 30 - 45 seconds before thoroughly rinsing with water
  • Agitate heavily contaminated areas with a brush or towel
  • Dilute and dispense using a 22 oz trigger spray bottle
Today's Daily special (November 21, 2009) is Dodo Juice Purple Haze Soft Wax.
Regular Price for 250 ml is $69.99. Today's price is $54.72!
Regular Price for 30 ml is $13.99. Today's price is $10.55!
  • A Dodo Juice soft carnauba wax designed to work exceptionally well on darker colored vehicles
  • Extremely easy to apply and remove, especially when applied in thin layers
  • Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
  • Can be applied with a foam applicator pad or literally with your bare hands
  • Dodo Juice soft waxes offer slightly more depth and gloss over the Dodo Juice hard waxes
  • Remove any Dodo Juice wax with a plush microfiber towel
Today's Daily special (November 23, 2009) is Chemical Guys Bug Bugger & Tar Remover.
Regular Price for 16 oz is $9.99. Today's price is $7.44!
  • Easily remove tar, bug splatter, sap, and other stubborn forms of contamination
  • Simply spray the product onto the paint, allow Bug Bugger to sit, agitate and rinse contamination
  • For maximum efficiency and easy storage use in a 4oz pump spray bottle
Today's Daily special (November 24, 2009) is Dodo Juice Time to Dry Drying Detailer.
Regular Price for 250 ml is $12.99. Today's price is $9.61!
  • Dry your paint faster and more effectively
  • Helps minimize adding imperfections during wipe downs
  • Reduce potential water spots on your paint
  • Best used in conjunction with a waffle weave drying towel
Today's Daily special (November 25, 2009) is Dodo Juice Diamond White Hard Wax.
  • A Dodo Juice hard carnauba wax designed to work exceptionally well on lighter colored vehicles
  • Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
  • Apply with a foam applicator pad and remove with a plush microfiber towel
Today's Daily special (November 27, 2009) is Chemical Guys 50/50 Limited Series Concourse Paste Wax.
Regular Price for 16 oz is $59.99. Today's price is $46.11!
  • Bang for the buck, one of the best carnauba waxes we offer considering you get 16oz of product
  • Offers outstanding depth and gloss as well as sharp reflections
  • Works great on any colored vehicle, light, dark, metallic or non-metallic
  • Easy to apply and remove when applied properly, which is as thin as possible
  • Best applied with a foam applicator pad and removed with a microfiber towel
Today's Daily special (November 28, 2009) is Dodo Juice Double Wax Kit.
Regular Price for 2 x 200 ml is $159.99. Today's price is $133.19!
  • A combination of a Dodo Juice hard and soft wax for the best of both worlds
  • Apply a coat of the hard wax for a base and longer durability for your protection
  • Top the hard coat with a layer or more of the soft wax for additional depth and gloss
  • For maximum results, allow for 12 - 24 hours between coats
Today's Daily special (November 29, 2009) is Dodo Juice Supernatural Wax.
Regular Price for 250 ml is $199.99. Today's price is $145.99!
Regular Price for 30 ml is $29.99. Today's price is $24.97!
Regular Price for v2 200 ml is $129.99. Today's price is $92.29!
  • One of our finest carnauba waxes we've ever tested, competes with more expensive high end waxes
  • Amazing gloss and depth that makes any color look liquid wet and shimmering
  • One of the easiest waxes to apply and remove, even when applied too thick
  • We recommend using a plush microfiber towel to remove Dodo Juice Supernatural
Today's Daily special (December 1, 2009) is DI Microfiber Super Gripper.
Regular Price for 16" x 16" is $5.99. Today's price is $4.46!
  • The ideal towel for removing light dusting on smooth surfaces
  • Attract and cling to dust with our grippiest towel we've tested to date
  • Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent
Today's Daily special (December 3, 2009) is Lexol Leather Conditioner.
Regular Price for 16.9 oz is $9.99. Today's price is $7.82!
  • Condition your leather to maintain a soft and supple, like new feel with a matte finish
  • Best applied just after cleaning your leather with Lexol pH Leather Cleaner
  • Best applied with a terry cloth applicator and wiped to desired finish with a microfiber towel
Today's Daily special (December 5, 2009) is DI Microfiber reTHICKulous Towel.
Regular Price for 16" x 16" is $7.99. Today's price is $6.05!
  • Thickest, softest, most plush towel we carry.
  • Over 3x thicker than regular microfiber towels.
  • Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent.
Today's Daily special (December 6, 2009) is Dodo Juice Hard Candy Hard Wax.
Regular Price for 250 ml is $64.99. Today's price is $50.49!
  • A Dodo Juice hard carnauba wax designed to work on any colored vehicle, light or dark
Today's Daily special (December 7, 2009) is Meguiar's Quik Interior Detailer.
Regular Price for 16 oz is $6.99. Today's price is $5.21!
  • Clean and protect plastics, vinyl, leather, rubber, metal, gauges, audio equipment and more
  • The one interior quick detailer you'll need to keep your car looking and smelling fresh
  • Best applied with a quality microfiber towel
  • Pick up a 4 oz pump spray bottle to easily store this in your glove compartment for emergency clean ups
Today's Daily special (December 10, 2009) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.31!
  • One of the most popular used wash mediums by professional detailers
  • Very soft and durable, while being able to hold tons of suds and water helps reduce imperfections
  • One of the best features of the grout sponge is that it releases contamination very easily
  • For maximum results, use in combination with a Grit Guard bucket insert
Today's Daily special (December 11, 2009) is Wheel Wax Wheel Wax.
Today's Daily special (December 13, 2009) is DI Accessories Sheepskin Wash Mitt w/no thumb.
Regular Price is $8.99. Today's price is $6.65!
  • Perfect wash medium to help minimize adding swirls and other imperfections to the paint
  • The natural fibers help pull contamination away from the surface without grinding them in
  • When done using, rinse any contamination using free flowing water than hang dry with leather hoop
  • For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
