New Daily Specials at www.DetailedImage.com
Today's Daily special (April 3, 2010) is Poorboy's World Super Swirl Remover 2 (SSR 2).
Regular Price for 16 oz is $15.99. Today's price is $11.35!
  • Designed to remove light to moderate surface imperfections, while improving the paints finish without leaving behind holograms or hazing
  • Can be applied in either the shade or in the sun, making the polishes great for mobile detailers
  • Works best when applied with a quality buffer, such as a Porter Cable 7424 or Flex XC3401VRG, typically using a white polishing pad
  • For accurate product dispensing, we recommend using a 4oz dispenser bottle or 8oz yorker bottle
Today's Daily special (April 8, 2010) is Lake Country Blue Fine Finishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.39!
Regular Price for 5.5 inch is $8.99. Today's price is $6.38!
Regular Price for 4 inch is $4.99. Today's price is $3.54!
  • Our softest foam pad, the blue fine finishing pad, designed to apply sealants and liquid waxes
  • Also commonly used to burnish the paint to a high gloss with a gloss enhancing polish
  • Jet Seal 109 is one of the most popular sealants to apply with a blue pad
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (April 9, 2010) is Stoner Upholstery & Carpet Cleaner.
Regular Price for 18oz is $5.99. Today's price is $4.37!
  • Powerful foaming formula that lifts dirt and stains from fabrics, carpets, mats and upholstery
  • Works great on headliners as it evenly distributes product and dries quickly after wiping
  • Does not leave behind a sticky film or residue
Today's Daily special (April 11, 2010) is Glass Science Rain Clear.
Regular Price for 5 oz + Bonus is $5.99. Today's price is $4.54!
  • Sheet rain and water off of your glass when you have it protected with Rain Clear Gel
  • Help maximize your visibility when driving in bad weather conditions
  • For a streak free finish, try to apply as thin as possible to your glass, then buff clean
  • Includes a sample of Glass Science Glass Scrub
Today's Daily special (April 15, 2010) is DI Accessories Gentle Fine Grade Clay.
Regular Price for 180 g is $18.99. Today's price is $13.48!
  • Safely and effectively remove tar, sap, paint over spray and more
  • Fine grade clay bars will not mar your finish when used properly
  • We recommend using Dodo Juice Born Slippy as your clay lube
Today's Daily special (April 18, 2010) is Menzerna Intensive Polish (IP).
Regular Price for 32 oz is $25.99. Today's price is $20.00!
  • A very popular medium cutting polish designed to remove moderate imperfections in the clear coat
  • Can finish down hazy, so following up with a finishing polish is highly recommended
  • Recommended application is using a buffer with an orange light cutting pad
Today's Daily special (April 22, 2010) is Poorboy's World Spray & Gloss (S&G).
Regular Price for 16 oz is $8.99. Today's price is $6.70!
Regular Price for 32 oz is $14.99. Today's price is $10.64!
  • Commonly used after a wash to help enhance the gloss and depth, while extending the life of your protection
  • Not only works well on paint, but glass, chrome and other areas of your vehicle
  • Easy to apply and remove without streaking when applied correctly with a plush microfiber towel
  • For maximum efficiency and convenient storage use in a 4oz pump spray bottle
Today's Daily special (April 27, 2010) is DI Accessories Medium Grade Clay Bar.
Regular Price for 180 g is $18.99. Today's price is $14.05!
  • Use to remove stubborn contamination such as tree sap, tar, rail dust and paint overspray
  • Large enough to break into several pieces for multiple uses
  • We recommend Dodo Juice Born Slippy as a clay lube
  • If you drop a piece of clay, throw it away!
Today's Daily special (April 28, 2010) is 303 High Tech Fabric Guard.
Regular Price for 16 oz is $14.99. Today's price is $10.94!
Regular Price for 32 oz is $26.99. Today's price is $19.97!
  • Protects carpet, canvas and upholstery from staining by repelling liquids
  • Makes maintaining interior carpets, floor mats and canvas seats significantly easier when protected
  • Works great on canvas convertible tops and outdoor patio furniture
  • For maximum efficiency use in a 4oz pump spray bottle
Today's Daily special (May 2, 2010) is Dodo Juice Diamond White Hard Wax.
Regular Price for 250 ml is $69.99. Today's price is $54.72!
Regular Price for 30 ml is $13.99. Today's price is $10.55!
  • A Dodo Juice hard carnauba wax designed to work exceptionally well on lighter colored vehicles
  • Extremely easy to apply and remove, especially when applied in thin layers
  • Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
  • Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
  • Apply with a foam applicator pad and remove with a plush microfiber towel
Today's Daily special (May 5, 2010) is Lake Country Hydro Tech Crimson Ultra Fine Finishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.44!
Regular Price for 5.5 inch is $8.99. Today's price is $6.47!
Regular Price for 4 inch is $4.99. Today's price is $3.72!
  • Bring out the maximum depth and gloss of any polish
  • Use the Hydro Tech Crimson pads to apply finishing polishes, glazes or even sealants and waxes
  • Experience longer work time and less dusting with less product absorption
Today's Daily special (May 6, 2010) is Meguiar's PlastX Clear Plastic Cleaner and Polish.
Regular Price for 10 oz is $7.99. Today's price is $5.75!
  • Ideal for use on headlights, tail lights, motorcycle windshields, convertible windows and much more
  • Restore clarity to clear plastics by removing stains and imperfections
  • Leaves behind a polymer protection for easier maintenance
Today's Daily special (May 7, 2010) is Poorboy's World Trim Restorer.
  • Restores neglected rubber, vinyl and plastic trim that has faded over time
  • For maximum results, prep the trim you plan on restoring with a degreaser and apply multiple thin coats
  • Best applied with a foam applicator pad and removed with a microfiber towel
Today's Daily special (May 11, 2010) is Lake Country & Backing Plate for Porter Cable 7424.
Regular Price for 125 mm is $16.99. Today's price is $12.57!
  • Use with Porter Cable 7424 XP and 5.5" Hook and Loop Pads or larger
  • Get optimal results with the 5.5" Lake Country foam and wool pads
  • Allows you to easily put on new pads and pull of the old ones in just seconds
Today's Daily special (May 12, 2010) is Chemical Guys Pete's 53 Black Pearl Signature Paste Wax.
Regular Price for 8 oz is $53.99. Today's price is $38.33!
  • A hidden gem of carnauba waxes, offering excellent depth and gloss and easy application
  • Excels on darker colored vehicles, but works well on any color, metallic and non-metallic
  • Easy to apply and remove when applied properly, which is as thin as possible
Today's Daily special (May 14, 2010) is DI Accessories Gentle Fine Grade Clay.
Regular Price for 200 g is $21.99. Today's price is $16.38!
Today's Daily special (May 16, 2010) is Dodo Juice Banana Armour Hard Wax.
Regular Price for 30 ml is $13.99. Today's price is $10.21!
  • A Dodo Juice hard carnauba wax designed to work exceptionally well on warmer colored vehicles
Today's Daily special (May 17, 2010) is Lake Country Black Finishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.29!
Regular Price for 4 inch is $4.99. Today's price is $3.64!
  • A finishing pad, designed to bring the paint to its maximum depth and gloss with a finishing polish
  • Also can be used to apply a paint cleaner, glaze or sealant
  • Menzerna PO85RD is one of the most popular polishes to use with a black finishing pad
Today's Daily special (May 18, 2010) is Lake Country Tire Dressing Applicator.
Regular Price is $1.99. Today's price is $1.47!
  • A perfect applicator pad to apply your favorite tire dressing
  • Firm foam design that will not shred like cheaper tire dressing applicator pads
  • Works excellent with Poorboy's Bold 'n Bright water based tire dressing
Today's Daily special (May 19, 2010) is Chemical Guys Luber.
Regular Price for 16 oz is $9.99. Today's price is $7.39!
Regular Price for 128 oz is $26.99. Today's price is $20.73!
  • An outstanding clay bar lubricant formulated to work specifically with your clay bar
  • Can also be used as a quick detailer to remove a light dusting along
  • Works great with the Chemical Guys Fine Grade Clay Bar
Today's Daily special (May 21, 2010) is Dodo Juice Sour Power Gloss Enhancing Shampoo.
Regular Price for 250 ml is $13.99. Today's price is $10.35!
  • Perfect maintenance shampoo that enhances gloss and depth
  • Lots of lubricity and slickness to help minimize adding imperfections
  • Concentrated formula means only a little product is needed per wash
  • Best used with a grout sponge or sheepskin wash mitt
Today's Daily special (May 22, 2010) is Lake Country White Polishing Pad.
Regular Price for 5.5 inch is $8.99. Today's price is $6.65!
  • A polishing pad designed to remove minor surface imperfections with an abrasive polish on a buffer
  • Menzerna PO106FF polish is one of the most popular products to use with the white pad
Today's Daily special (May 23, 2010) is Optimum (OPT) No Rinse Wash & Shine New Formula (ONR).
Regular Price for 32 oz is $15.99. Today's price is $12.83!
Regular Price for 128 oz is $39.99. Today's price is $33.23!
  • Improved formula released in Feb 2010, experience increased lubricity and a more pleasant smell
  • Properly wash your car without the need for a hose source
  • Can also be used as a quick detailer and clay bar lubricant
  • Go-to product for many professional detailers
