AmsterDutch
Have you unplugged the MAF? If you have is there any difference? Throttle Position sensor?Mind you also, that cold start is usually fine, but once it reaches operating temp is when it acts up.
Yes. Dies when you pull maf. Tp sensor is new.Have you unplugged the MAF? If you have is there any difference? Throttle Position sensor?
Yes. Dies when you pull maf. ...
OkThat's not what he meant. Unplug the MAF while the key is off, then start the engine and see what happens. It will run with the MAF disconnected, using default estimates for air flow. You should never, ever, unplug it while the engine is running!
I tried it out tonight. Car would start then immediately shut off. Each time I tried it.
Wonder what’s up with that?Weird, it shouldn't do that.
Would I not have a code for crankshaft position sensor?Replace Crankshaft Position Sensor...what do you have to lose ...it may be a faulty throttle position sensor also ....did you unhook the battery of 30 minutes after installing new throttle?
Where is that sensor located on a gen 2?
"If the car dies when you disconnect the mass airflow sensor, then that means it was working right and that your computer has issues. It isn’t able to use the tables programmed in it to guess the amount of fuel needed. Also, if the computer isn’t the issue, then it means one of the other sensors is probably off if the car isn’t able to keep running without the mass airflow sensor because the sensor was helping the car compensate for the other issues that it was having. So as you can see disconnecting the mass airflow sensor is actually a good way to test a variety of things." Reference from AutoGuyLandWonder what’s up with that?
Where can I get a forscan and what model?Bottom of the engine at the back. You would have a code. I really don't like these random throw parts at it suggestions. There's no reason to disconnect the battery during/after throttle body swap. I don't know where that thought is coming from.
Maybe time to get Forscan and chart some stuff, like fuel trims, air flow, throttle position, and so on.
Download it on smartphones which would be Forscan lite $5.99 does everything that Forscan for Windows on laptop does if you go with Forscan for Windows it's free downloadWhere can I get a forscan and what model?
Thank you. Just ordered it.Download it on smartphones which would be Forscan lite $5.99 does everything that Forscan for Windows on laptop does if you go with Forscan for Windows it's free download
FORScan OBD2 Adapter, VINT-TT55502 ELMconfig ELM327 modified For all Windows compatible with Ford Cars F150 F250 and Light Pickup Truck Scan Tool, Code Reader MS-CAN HS-CAN Switch
Download it on smartphones which would be Forscan lite $5.99 does everything that Forscan for Windows on laptop does ...
Forscan lite allowed me to reprogram my ABS module and steering and yaw rate sensor...did the same service as the Windows version...Never had to update the PCM but it's on Forescan Lite alsoSorry, you couldn't be much more wrong on this.
Forscan on Android or IOS is just a little more than a code reading tool.
Forscan on Windows allows you look into a lot more and do some programming, including PATS.
Yes I agree you should disconnect the MAF while car isnt running....I can't agree more with this statement though..... It should run (not well) with the MAF disconnected, but you have to disconnect while the engine is off!
I'm wondering if the version I downloaded has been updated and revised compared to the one you downloadedSorry, you couldn't be much more wrong on this.
I meant recalibrate my ABS and Yaw rate sensorForscan lite allowed me to reprogram my ABS module and steering and yaw rate sensor
I also tried disconnecting it while it was turned off. Started but then died immediately.This is not very correct for the LS. It will normally stall if you unplug the MAF while it is running. It should run (not well) with the MAF disconnected, but you have to disconnect while the engine is off!
