I think I'd get a full engine harness from a junkyard and try that first. (Okay, actually I'd scope it and find the problem that way...)
My mistake Joejr...i took it for granted.....well do you think i SHOULD REPLACE the battery first and foremost? Or at this point it doesn't matter???....It (that you have a bad battery) certainly would have been good to know to give better advice. BTW, a bad battery is also a good way to kill the alternator.
Yes, the whole electrical system has to be good. The battery, the alternator, good ground connections everywhere (ever check those ignition RFI capacitors on the manifold?), and clean power connections. This may not be the cause of your problem(s), but it could be.
Also, note that the "ecm programmed" will still require a dealer or good scan tool to marry the PCM to the PATS and keys before your car will ever even attempt to start.
i understand what your saying joejr, but im tryin to do the best i can with what i can do....i currently cant drive the car due to not having a licensePersonally, I think you need to find someone with the right equipment and experience who will correctly diagnose this for you.
With all due respect, the 'Motorcraft' label parts aren't magic. What we're dealing with is easily-found cheap parts that cause problems, as opposed to also easily-found quality parts.
Sixty thousand miles ago I started a significant effort to go land-speed racing with my '02 LS Sport. I installed an NX Pro nitrous oxide 'spray' system and along with an ancillary methanol delivery set-up, I set the record in E/F CC---and the record still stands.
As part of the upgrade I put in a set of Accel coils originally intended for the base 4.6 litre engine in a Mustang. I also used the Mustang-intended spark plug boots since they are designed in such a way as to seal the plug wells.
They are still working just fine, and all eight of the Accels were selling for something less than $300.
Just a FYI
KS
Vent connection?I went for a stronger battery with NAPA 850 cranking amps in my 04 LS. don-ohio^)
Purchased the vehicle for once i received my license back, which is next month. Understand the systematic fails....purchased a new battery sunday and had it placed in.Ehhhh... why do you have a car if you don't have a license. Yes, the battery needs to be good, particularly on the LS because it is very sensitive to poor power. The dealer sells the correct vented battery, and the dealer sells them for a competitive price. It's best to replace the battery and alternator together when one fails hard, because they are symbiotic; when one fails, it kills the other, and can set up a fail cycle where the alternator dies trying to charge the bad battery, and the new battery fails because the failed alternator isn't charging it.
honestly, there are so many variables right now now, no body can possibly tell you what is wrong with it with out a lot of testing. and before ANY testing can even be started, the battery must be fully charged and in good condition.
if the mechanic has to keep jumping the car because the battery is dead, then that battery has probably already been damaged and is no good (luckily, there is also a test for that)
IMHO, there is about a 3% chance you will be able to fix the car if you keep going at it like this.
or just drive as it is...meaning that once the car is in operating temperature and works stable, wiiith check engine light. Thoughts?
this would probably not last long... I'd be surprised if the problem doesn't get worse and worse...
Run the codes again. don-ohio^)
My mechanic did, same 2 previous codes. P2106 and also P1000 came back up.
