the1andonlyGR81
Please use punctuation in your sentences. Bass is mono and if i recall im running my sub of a monoblock amp. Sure you can have bass in stereo, but the way songs are setup most of the time the basslines are in the center of the soundstage. Really no need for a left and right when both subs are in your trunk and not left and right of you.
Ported is louder. Sealed is more efficient. You dont need multiple subs to hit hard. Like i said, you can buy a stronger sub and amp that is matched to it.
A single sub and amp will not blow your speaker. Im running an Audioque SDC 2.5 with 500rms @ 2ohms. The sub is rated for 600rms and no its not going to blow. And if it did...recone.
Are you against sending lots of power to a single sub? They do make subs that can push 2000rms now all day long on music not just burps.
Those kickers suck imo...much better out there. Especially the solobarics. The world records in db arent held by kicker or mtx or even JL. I believe its DC right now. Followed by Digital Designs and some with Audioque.
Ive heard single sub system put multiple sub systems to same. Its all about the right setup. Just informing the op that you can do a lot with one sub. Did you really say to go buy a crunch amp? Lmao im not a newbie with car audio...my amp is also an Audioque amp and if you wanna check it out its not a light weight: http://www.audioque.com/AQ1200D-Amplifier_p_30.html later on i plan on getting a stronger sub and running it at 1ohms to get the most of the amp.
for the umpteenth time.PORTED ENCLOSURES ARE NOT LOUDER THEY ARE JUST TUNED TO ONE FREQUENCY.
thats what they were designed for. if you like a kickdrum double bass like metallica tune the box to 80-100hz, if you like synthasized bass like rap tune to 60 hz. it will seem louder at that freuency but be NOT louder acrossthe board. if you put a sealed box and a ported box with the same speaker in it and powered it with the same amp if its tuned for techno rap at 60 hz. and you play hard core metal with lots of kick drum and a good thumpy bass groove it will sound weak as opposed to the sealed box, however if you played your techno mix, the ported box will have a noticeable increase AT THAT FREQUENCY.
they are tuned by the diameter and length of port. hopefully this will sink through the 3rd layer of your medula oblongatta, its really not that complicated. the crunch sub and amp are garbage, it was just a reference, and yes my subs are not the best, but the box is the proper size coupled with proper watts for what i need, didnt feel like dropping 400 for one sub at the time.i chose to put $$ in motor instead. before you go making statements be sure you know what your talking about as a matter of fact bandpass, ported, and sealed enclosures were all designed for a specific purpose and its all in the dictionary .and if you wanted to grade my punctuation you should have come prepared with the knowledge on the topic. thank you for letting me channel my inner a$$hole, i needed to vent, thank you,
good day sir
I SAID GOOD DAY!
