PGA2B
Quik,
I put two bottles of Redline Water Wetter per two gallons of fluid in my main radiator (I know that is more than they recommend) and it helped overall engine temp alot and I filled my intercooler radiator with only Water Wetter and 1 cup of coolant (for seal lubrication for the pump). It was a 4 gallon radiator from a VW Sirocco. The intercooler dropped my temps by 154 degrees allowing me to run a 2.6" pulley with 15 lbs of boost, no KR, and 24 degrees of timing on the street with proper tuning. Here is a pic of what I was using
Now I know mine was an air to water and a different setup but dropping temps is the end result we both needed. I suggest you try some Water Wetter!!
