This thing is cracked causing my car to overheat
I still do find this thread most entertaining!
You simply can't make this stuff up, it's real life!
Poor LS.....you should really research more. Nevermind, too late. The stupid commercials that say 'just fill it up with this can and you will be cool' just F-d your LS. If it was really that simple, why would anyone ever take it to a shop?
Ok how can you tell
because the things you did and the way that they were done will destroy a good working or ever a new system...
for starters (and why i asked that question early) is because for the system to work properly, it need oil, oil is added in WITH the refrigerant, so since you didn't add any, it would kinda be like draining the oil out of your engine and driving around without putting any back in. of course the engine is gonna blow up... now add that on top of when the compressor is ran with out oil in it, it grenades itself, meaning that it chews its self to bits and little tiny chunks of itself get pushed all through the system destroying every other part of the system. literally every part of the system will have metal shavings in it any will have to be replaced.
And how much am I looking at for a new one
probably thousands
If its even worth it......
probably not...
Ok how can you tell
You ran it with very little oil, a probably clogged dryer, and with air and (more importantly) water in it. The compressor needs lubrication, not water to make it rust. You have to pull a really good vacuum for a while to get all the air out and to boil the water out. You have to have the correct amount of oil to lubricate the compressor. You need a new dryer to catch any remaining traces of moisture before it mixes in and becomes acid...
I'll just inject this here for grins.
I changed my radiator in 2010, which included removing hoses to the condenser.
After reassembly, I put it all back together and charged it with new refrigerant. It worked fine for a couple of weeks, but lost pressure. It turned out that the O-rings on the receiver/dryer had flattened in the 10 years of being sandwiched in there, and I was able to replace the O-rings that had been disturbed, and the system held its charge with no recharging needed for 5 years until I had to pull the engine 2 months ago. It was able to put out 33 degree air before the engine change and still does now.
I'm kind of thinking that the system lost pressure due to O ring leaks. In my case, the problem was easy to find, using a leak detector. I could also see an oil film developing around the receiver/dryer manifold connection, when mine leaked out.
This time around, it was all new O-rings, since I had to change both manifold pipes from the compressor and the expansion valve, as well as the receiver/dryer.
You can rent gauges and vacuum pump from Autozone now. As long as you have around $300 to cover the cost if you decide to keep the stuff, you need to pay that up front and then get a full refund upon returning it.
