rocket5979 said:
Just so ya's know, it is the PTEC processor in these LS's not the Black Oak. Still a 1024k processor but has its minor differences.
Rocket - where are you getting your information?
"Black Oak is the Motorola Power PC system that is now in use by automobile manufacturers. There have already been other Ford vehicles using it for few years like the SVT Focus,
Lincoln LS, and the Navigator."
"The PCM is connected directly to the engine, transmission, and body wiring harnesses to minimize the number of leads and connectors. It regulates fuel delivery, the coil-on-plug ignition system, transmission operation, speed control, the electric fuel pump, the hydraulic cooling fan, and the thermactor air injection system.
Communication and decision-making speed is enhanced by the new Power PC 32-bit reduced instruction set chip (RISC). This microprocessor has one megabyte of read only memory (ROM).
It uses floating point arithmetic and high-level C-language modular programming consistent with standard corporate protocol (SCP) multiplex communications architecture. Input and output tasks and signal processing are handled independently of the central processing unit (CPU) to speed its operation.
Task-based versus loop-time-based programming also speeds the powertrain control computer's response. It can be flash programmed to suit whatever subsystems are installed in a particular car, including different engine and transmissions."
