the electrical connecter you mean the round part with the pins inside and then something in the middle of that
how can I unscrew this bolt I cant even see it
You should be able to see it. Are you on a lift or jack stands?
jack stands I cant see sh!t except for the bottom of the solenoid pack which is all black sh!t
I've taken out all 8 bolts and the fuking thing is still not coming out
It's in the middle of the electrical connector on the outside of the transmission, above where the solenoid assembly is on the inside of the transmission.
basic msds info should be on the back of the mercon v bottles, including what to do in the event of ingestion and so on.
My guess is your eye will move in its socket a little better now.
I'd like to ask a question here while everyone is being so helpful.
My transmission has just 1 symptom. It works perfectly is every other way.
It works fine until the car warms up. This is about 1-2 miles. The problem then gets progressively worse as it reaches operating temp.
The 2-3 shift fades to useless at temp. I have to speed up to about 40mph and then let off the gas and wait for it to go into 3rd or 4th with no throttle. If I don't back off, it will "hang" between gears until it slams into 3rd(sometimes chirping the tires or giving the E for unexpected pressure differential)
Is this solenoid pack?
Spring?
Servo?
Coils and plugs are all new Visteon and Motorcraft BTW.
I haven't found this specific symptom by itself in any threads here.
I want to save up the money and throw it in the right direction.
Thanks!
I've done that several times.
It started doing this right after I let off the throttle during an aggressive takeoff. I accelerated at WOT through 1st, 2nd and let the throttle out at the top of 2nd. It BANGED into 3rd at 6k rpm with no throttle. Ever since then, it has had 2-3 issues.
If the code was for the solenoid I'd put my money on that, but there is a spring that breaks in the Ns. I don't think its for 3rd though. Here's a good write up, it might help. http://www.lincolnvscadillac.com/showthread.php?t=80761
Crap! I didn't write down the code and it clears itself after I behave.
It has to to with pressure.
I'll check codes now and see if I have a pending code. I was not paying attention to nursing it on the way home today and the wheels chirped into 3rd...
I wasn't sure if servos could throw a pressure code.
I would prefer changing the solenoid pack since I've read up on it so much that I feel comfortable doing it myself.
In fact, the only thing I dread is filling the trans fluid. What a goofy setup for fluid fill!
OP, whats the word on your issue?
jrands solution to any problem you have with your car disconnect reconnect your battery
need an oil change? no problem disconnect reconnect your battery
got a flat tire? disconnect reconnect your battery
car doesn't warm up fast enough in the morning? you guessed it disconnect reconnect your battery
LOL
LOL
I'm pretty sure 99% of the members here have placed him on ignore. You'd be wise to do so as well.
