how much did the dealer charge you to reflash the pcm?
$75.00
I put him on my ignore list a long time ago. Maybe you should too...
it sure is
so tell me why does the transmission shift harshly when put into drive or reverse? the car is in idle not much stress on the coils
if I remember correctly i did have a bad coil once and I only felt the misfire when the car was in idle not in drive or when it was shifting and there was gas smell also and my engine light was on at the time i have none of these symptoms now
your telling me the coils misfire when the car shifts gears to try and get me to change the coils for nothing so i waste my money
heres what another member had to say about your bogus advice
"I don't know where you get your material but it is generally bogus. You don't need to periodically calibrate the transmission, or relearn the battery. RED's symptoms were classic for a solenoid failure. I had one fail on my '00 at around 90K miles. Still in warranty but I stupidly followed what your advise was and ended up having to have it done on my dime as I waited too long.
RED, the recall was for the valve body, NOT the solenoid pack. There was a needle valve that wasn't machined correctly (I got to see one at the trans factory in '03) and had a bur on the end, causing it to stick. " LS4me
after doing some reading on solenoids and PCMs I think I should get the PCM flashed at the dealership
does the PCM not fully get flashed when the battery is disconnected? (disconnecting the battery does solve my problem for a few days) what the does the dealership do?
are there any PCM firmware updates for 04 LS to address harsh shifting issues??
I just received my solenoid pack from tascaparts is it normal for it to have transmission fluid all over? there's fluid in the bag and part like it was takin out of a transmission put inside the bag and shipped
If you have harsh engagement from park to reverse and from reverse through to drive, then it is almost certainly the solenoid assembly.
wrong.
he has harsh engagement bc he keeps disconnecting the battery w/o getting rid of p1000. its never learning how to 'engage' period. its too cold in canada to get rid of p1000 this time of year. end of story.
unless there is a sequel to the story, that has something to do with lking trying to use the shift lever before the car has dropped its rpm from initial startup (15 seconds usually, but sometimes longer when its cold like it is all winter in canada). in these instances it will always engage rough.
There's 8 bolts
