Depth at bottom is 12.5" and 6.5" on top
But the sub fits into it at an angle.
yea i guess but then everyone is going to have the same box thats the only thing i hate
And you are down to not very much volume. Can't remember the specs off hand, but I don't remember them having the construction/volume requirements to fit any type of big boy sub.
Correct. The angle is minimal though. I have no way of measuring it. But your right it could be a close one for subs with larger diameter drivers.
Aq2200 that's a great amp. That's what I'm running my xl on and it is solid, doesn't overheat or even warm up too much, clipping indicator on bass knob, oveall a great amp.
I'll be running it on a lvl4. Probably should've bought an XL, but these subs take a licking! Plus, that's just too much weight in the trunk for how low my car is right now.
same box but different subs and setups....just like most of us have angel eyes.
You seen how large my sub is and it fits it just fine.
AQ amps are the :q:q:q:q...i have an aq1200d and it doesnt overheat in 106 degree texas weather.
Yeah but that's just on here. When are you ever going to run into another ls with anything similar to yours, unless it's at an LS meet. Unless you want be the ONLY one in the world with whatever you have, you dont really need to worry about it.
For some reason I forgot you had this box. Guess it shouldn't be a problem then!
Yup when you purchase the box you send the guy the sub specs and if the sub wont clear the box he wont even build it.
The boxes arent premade...
