It's been a couple of weekends -
I have the wideband installed now.... used my new lift to get to it...
First - the product I am using the LC-1 Lambda Cable - from Innovate MotorSports
http://www.innovatemotorsports.com/products/lc1.php
so the way this works -
- the new wideband O2 sensor into the exhaust bung, the other end into the LC-1.
- the LC-1 then plugs into the analog-in port of the SCT XCalibrator2.
- the SCT XCal plugs into the ODBII port
- the SCT USB port plug into your laptop
- the laptop runs SCT's LiveLink and you can now datalog all the SCT parameters as well as the analog input - which is the LC-1 Air/Fuel measurements....
I then ran the leads form the LC-1 controller into the cabin through the firewall.
Wired it into power and the analog cable that then plugs into the XCal2.
Pic#1: the secert firewall passageway just to the left of the brake pedal pass-through
Pic#2: the plug in the firewall hole - the controller fit through that
Pic#3 - Here's a pic of the exhaust bung (above and to the right of the stock O2 sensor)
Pic#4 - wideband O2 sensor installed
Pic#5 - pic of the O2 sensor wiring tie-wrapped to the fluid lines of the steering box
Pic#6 - a pic of the controller hidden up in the engine bay (under the degas bottle)
