SPSully
well.... first I want to say gear wrenches are the poo!!!! Make sure they are flex heads like the like showed. I think I might use those more than ratchets now. The only issue I found was finding a complete kit. I bought one metric and one SAE, then knowing the sizes I use often, just built onto the kit as needed. 8mm was the big one for me. I think 10 and 8mm are the two most commonly used sizes in these cars and 7mm is right behind them. It's odd because I'd figure 12 and 14 would be.... oh well.
As for the electric fan.... I'm getting ready to do my timing chains/cams and have an electric fan. I guess if your still not back together by then i can show you everything involved.
Dirty oil gunk.... I had a pretty nasty crank case when I did my VCG's. I may at some point hot tank the whole damn motor, but what I did as a for now thing, at 2k miles I pour half a can of sea foam into the oil. I change my oil about 500 miles after that. I havent pulled anything off to see how much better it is, but after one application I did the drivers side vcg (that project got done in two steps due to a screwdriver through my finger) and it looked noticeably better than my passengers side. I've done the seafoam thing a few times and by keeping the oil and filter fresh, I know I'm not adding much if any build up. The added detergent in the seafoam should be cutting down on the old stuff.
pics to make you feel better:
