i might run 235 or a 245, and pull the fender out a bit. I neeeedd lowering springs!!!
Me amf thr captitn too so wlell aloong tonignth there are two forums tonight!
bo work on on the
Ls today1
Time for the hot tub!!!!
Lol... the captain is watchingme! my head hurts this morning, too much Captain last night, somehow found LVC with one eye covered up.![]()
Test fitted some American Racing Torque Thrust II 17x9 in the rear. 275/40/17
I used an adapter and the rim sticks out about 1.5", but the wide tires make it look horrific. i might run 235 or a 245, and pull the fender out a bit. I neeeedd lowering springs!!!
Use 'Di-Electric' grease
The application of any sort of non-conductive grease to the actual contacts themselves can't help them make better contact at such point. You have to hope the grease gets squeezed out of the way so the two conductors can make contact. Any grease left in there is going to reduce the contact, not improve it.
If the contacts are not perfectly clean, you'd be better off using something like WD40 on them. WD40 is designed to restore electrical contacts. It is a decent solvent and will get rid of a lot of corrosion and dirt in the contacts.
~ just a thought.
Did you know Bacon is a great hangover cure! or maybe it's just because it's so damn good it makes you feel better like chocolate.
dehydration was the real problem ... several cans of 5 Alive and 3 Advil's fixed that issue. Should have dranken large glass of water before bed but didn't.
Mounted a set of 19" Jag XJ8 wheels with Conti DWS tires....pictures to come later
Gatorade and brown rice the night of drinking. Lacking water and electrolytes is what causes a hangover. The brown rice (fiber) is for the other end. That works for me.
Well aware of what causes hangovers, tiny brain cells get dehydrated. Usually don't have problems with 26oz of the Captain but it was a large party and there was more to it if I recall correctly.
~ just a thought.
The silicone grease isn't there for better conductivity, it's to seal the metal of the connectors away from the elements. The sliding action of putting the connectors together clears enough grease away to make contact. My problem wasn't with the grease, it was with the connector lock not being strong enough to keep the connectors together. The wedge I put in is holding the lock in place and will keep the connectors together. Thanks though, I do appreciate the thought.
Di-Electric grease is not that expensive.
