(Little) progress report
So I attacked this sway bar bushing project today and was able to get to the point where I only have 2 more bolts to remove - the one at the 45 degree angle holding the DCCV bracket on and of course the front passenger side bushing bolt which is under the DCCV. I hope to get those out tomorrow. Going to attack the 45 one from the top. 2 things happened during this work:
1) Once I got the three bushing bolts out I was able to move the sway bar around fairly freely. I noticed at this point that the bushing on the passenger side is NOT bonded to the sway bar as the bar rotates freely within that bushing and even moves side to side a bit. I'm thinking there may be a chance I can force that bushing and bracket off the bar without cutting it. We'll see.
2) Unfortunately during the freely moving the sway bar around fun time, the bar somehow contacted the pressure line from the PS pump in such a way as to cause a leak at the pressure connector on the underside of the pump. Great. So looking at the Lincoln DVD I see there's a seal that's supposed to prevent this that should be inside on the threads. So I got a little side project now to find this seal and the 'special tool' needed to install it and see if I can stop the leak this way. Hoping I wont need to get the entire hose cause it's bound to be expensive. Course luck says the copper? line got bent a little at the compression nut and will need to be trashed. Yeah I just looked on rockauto and these parts are surpisingly inexpensive. But there ae several similar and some not similar and how do I know which one I need and do I dare think it's NOT the one that's 'out of stock'. If anyone has any thoughts beside 'you knucklehead' cause I already had that one please chime in. Otherwise happy weekend to y'all. Not so much for me.
Cheap tool. Just need a good compressor (and eye protection).
