Telco
As a parting shot, what did I do to my LS today? Tried to remember what it looked like... and failed. I'm so happy!
... and we are so happy for you as well. Nothing makes the rest of us more happier then seeing a miserable LS owner stuck with it for some many years and finally rid himself of his troubles.
Good on you Telco! You got rid of the car you hated the most for all these year. Sure do hope you stick around for a long time reminding us of how much of a POS this LS really is huh?
Great contributions Bud!
... Their location would be at the back of the block, directly below the rear of the driver's side cylinder head. ... What else could be the source of a coolant leak that would dip in the area I noted? ...
Yellow could also be motor mount fluid. Had this happen on my 02
Could be, but the motor mount fluid that leaked out on both of my gen IIs (2004 and 2006) was dark red.
Thanks.9 hours! Nice job.
On the cleaning - I am also tearing down a 3.0 and I want to clean it up. This is my first engine teardown and I'm wondering how/what you used to clean it?
It seems like there must be a fair amount of time between when the fluid leaks out and when the mounts finally collapse, so I don't think there would be any immediate symptoms.
There is florescent factory dye in the AC system. I would say that it is more green than yellow though. It would normally show up under the front driver side of the engine, since the compressor is the most frequent leak site. Have a look at the bottom of the AC compressor to see if it is wet and oily.
Okay I changed the oil over the weekend and spent some time under the car looking for any possible source of a fluid leak. I pulled off splash panels, I looked at the a/c compressor, check out the motor mounts, the engine block, the fire wall and inner fender unibody sheet metal, I looked everywhere and found nothing. No runs, no dips, no sign of any leakage. The car has not dripped anything before or since, so I am baffled. The back side of the a/c compressor was slightly damp and grimy, but if there was a leak it was a long time ago back by what looked like an access long narrow plate that is held on by 2-bolts. There were no sings of any fluid on the top of a splash panel right under the compressor. I ran the a/c system and got ice cold air though the vents so the charge isn't low.
I finally got rid of the squeaky outer bushing in the rear lower control arms on my '04 V8 Sport with 51K miles. I followed 04_Sport_LS direction in his post here;
http://www.lincolnvscadillac.com/fo...(pics)&p=2037390415&viewfull=1#post2037390415
I filled the grease gun with Mobil 1 synthetic chassis grease and gave them about 5-6 pumps each. Wiped them clean. Put the wheels/tires back on, lowered her back down on the ground, push down on the rear bumper a couple times (like you would to test for a bad shock) one very short little squeak and then silence. Drove her around the block slowly with the windows open and enjoyed the sound of no more squeaking. Got in and out of the car - no more squeaking. It is a heck of a lot cheaper, faster and easier than having to replace the LCA. Now will those LCA still have to be replaced - most likely, but at least not right now. I do know one thing for sure, when I do eventually replace them, I will drill & tap the new ones and install grease zerks into the outer bushing before bolting them under the car.
