isaiah3g
Woops, nevermind that picture comment. It worked just fine. Sorry the pics are blurry, I had the camera on manual focus. Late night pics are no good for me. ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Got deez in! I tried uploading them the normal way, but everytime it failed.
Don't know when I'll put them on. Its been raining allot down here in Monroe.
163 for front and back from ebay. They are Brake Motive brakes.
That looks really good man.
On the cheap Thaywood!
Except those dingy ass headlight housings lol![]()
Thanks! Just cut and pasted the Cobra's wheels to the Mark. Maybe I'll do it for realsies someday
I'll get to it eventually...stop buggin' me![]()
Break out the 1000 grit sand paper and start wet sanding and finish off with 1500 and then buff out with Plastx and then spray a clear over them that's made for high temp and you should be set. You have air tools and a decent compressor? DA sander?
Juss messin withya thaywood. Really is a nice looking car. I think you have the same color as me. WK code?
Luckily I have no faded spots but I did call Maaco about painting a front bumper cover and over the phone, they quoted me $500 to $600 because it's a three stage paint. Not sure what they would charge if prepped already for them to just spray the base and then apply the opalescent and clear. Makes me want my single stage black 94 back again. I was able to paint that car and did paint most of it. I mention this because you said you had a faded spot on the fender but I can't see it in the pic.
Yes, ceramic pads for sure. I think those dingy headlight housings go with the white-out of the car.![]()
If you want to black out your trim it is fairly easy, just time consuming. Start by getting yourself some fine sand paper (600, 1000 grit), blue 3M painters tape and lots of news paper.
Tape along and around the edge of your trim very closely, and put some news paper around the rest like Omen did, then use the 600 grit and rough up the trim, use some water with a little dish soap in it to keep the sand paper from loading up..then once its scuffed with 600, move to 1000 grit and make sure it's all scuffed...then remove all the old tape and news paper..clean off all dust and water with some denatured alcohol..or some kind of mild solvent to get grease and crap off of the mouldings.
Then re-tape around the trim again (make sure its very close to the edges of the trim) and put lots of news paper around the trim to cover your car enough so over spray doesn't get all over.
Buy some black spray paint of your choice (something with the highest gloss you can find) and apply several coats onto the trim, waiting for each coat to dry before spraying another coat.
tip - practice spraying on something else first and get the hang of applying thin even coats so it doesn't run!!
wait for it to thoroughly dry before removing tape. and you are done!
and that would be to do the grille, chrome strip above headlights, chrome strip above tail lights and the trunk lock cover? or would this be for the chrome trim on the bumpers and moldings?
