DLF
Looks like you used a spirograph...
That's when the TC locked.
90% of the led strips are 1/8" wide or smaller. most are desidned to stay on outside of the car.you really dont have to take out the light excpt to make connections or put in projectors.theled strips can go on outside in the small crevice between the light and anything around it.theres a shop down the street from my house that sells the 6k led strips and they just stick to outside of the edge of headlight. i was going to do it with the projectors,factory hid's and halo's, but somebody beat me to the halos because i keep blowing motors!the package will still get done, just not for a year.i guess i read something wrong again, the side marker behind the screw at the end.
300@6, I thought you had some major mods D
I think that's a pretty good show of power. That is 303hp to the rear wheels. Which means at the flywheel it's probably making about 360hp give or take. By comparison, a stock 290hp 4.6 would be putting about 240hp to the rear wheels.
Nope, just a few simple bolt-ons.
Thanks.
I was just planning to ignore Sap.
If you take the HP that the Drag Times calculator estimates for my best run, and then reduce it by 15% for driveline loss, you get 303RWHP.![]()
Thanks.
ive read your stuff on lod. the intake swap you didhasnt been dyno'd till now,right? what other bolt ons.still b headed with trhat 98 intake unless you had one hell of a port job! thats th only reason i want the 03 marauder heads andn intake. the heads are good for
+20 hp across the board, stockw/out porting then its like 50hp. i should've been a little above that ith my cams before i blew it again.![]()
It's actually the second time I've had it on a dyno since the intake swap.
Neither the intake nor my heads are ported.
time slip? of course there is a time slip.
So, I must say, time slip from a track or it didn't happen.OMG, watch him have a time slip...
Damn, do I have time for a Ninja edit????![]()
Sorry Doug, didn't see the slip till Chris brought it out. I owe you a big apology for even asking that question.
I think we have time to do a ninja edit. he must not be looking. He's usually fast about firing back. :lol:
busted!
Sorry, you're busted!![]()
Ok, now I see a slight difference between the two. Never watched one right after the other but I put WMP right beside the youtube video and now I see.
Great.
Now, instead of questioning your betters, go run some times of your own. :shifty:
Ok, I just watched that video. Had to open it with WMP.
Maybe it's just me but your run that I just seen appears to be faster looking than Don's car. I see his times, when he runs and slips and not doubting him at all but it just appears that your car is getting down the strip a lot quicker but he has faster times. Any reason why that is?
Chris, since you're up and showing slips and stuff, do you know what I'm talking about too?
I always get busted. Isn't it past both of your bedtimes lol.
:why:
just not used to seeing a gen 2 go that fast.![]()
but yeah, don doesn't look that much faster, but he certainly is.
yes. i'm outta here. :lol:
