chris2523
93 Mark VIII
looks that way..
that's how i got the one i messed with apart.
yessir, @33000 rpms with a mini carborendum (sp?) cut-off wheel; I was not sure where to make my line so I just picked the center of the black seam; to the outside of the little black tabs; it makes a terrible dust by-product so i suggest using a fan to get rid of it and a maskHow did you get that apart? Dremel?
I do believe I read on here how putting the light in an Oven to heat it up the lens to separate it. I have a spare set from my '96 after I switched to LSC lights but am Gen II now so no need to use em.
BINGO!I've heard that too. Of course, I've read more threads where ppl have TRIED and ruined their lights. Even though we have heard of the few successful ppl like Jamie, I've seen more ppl ruin the lights. I tried once, but the glue would never get soft enough and I didn't want to destroy the set so I gave up.
BINGO!
I feel much better with a cutting tool in my hand
so how do people ruin lights in the oven?Either place the housing in a baking pan, and turn your oven to about 250* for a few minutes or
I personally use a heat gun (set on 300*) and heat the backside of the housing at the edge, where the groove is that the lenses sit in. Its not really that bad, and you DONT have to pry them that much. Once you get it warm enough it'll just pull apart. I suggest a pair of leather gloves thou
Try it! *shrug*so how do people ruin lights in the oven?
yea..noTry it! *shrug*
yea..no![]()
Same way they ruin anything that gets baked in an oven
You can't just stick it in before you go to bed and hope its apart before you burn to death
Looks like the fuel pump went out on the97. Crank no start
Unplug the crank sensor and plug it back in. Quick fix cause both my Gen 1 and Gen 2 suffered from that.
