Hot*Mk8
Nice! Welcome, Miksweets :W
Pics of your car, please
So i found wheels at pepboys. And used tires. 235-40-18 front 265-35-18 rear for cheap. What does. The hive mind think?
more fuel you going power adder?
No luck can't get it go quit running thru the cycles and then say NO CD. But getting my starting fluid to check for leaks and then grabbing some seafoam for the weekend cleanup and oil change.
airrides fixed on the 98, headers bought for the 97 and 4.10 gears and traction lock rounded up also. cobra intake someday. thanks everone who help me with the airride i also had to replace the compressor. but the car rides nice and stays up.
Every car forum I've ever been on has one of these as a sticky....
**hint hint**
Today I managed to get my autolamps working. Removed the top pad and started testing the ambient light sensor. Somehow it just started working.![]()
my autolamps will not go off unless i remove the horn relay located under the hood. also with the relay out my interior lights do not work, nor my electric locks.
I have change relay, change dimmer switch, change sensor light,
thought you might have a suggestion
thanks
No pics of anything? Someone will say, "pics or it didn't happen" lol
okay here are the headers. and more to come.
