Miksweets
Its a great investment for northern cold nights and averages below freezing more than just a few days out of the yr. It helps
Sorry but if it ain't diesel I see no need for it.
So do you know what a block heater is for? Apparently not.
I can understand how people up in Minn, N/S Dakota and Canada need them as it gets downright nasty in the winter. It doesn't get that cold down here for very long periods of time. Tuesday it isn't going to get below 10 degrees all day with a low of -9. I might consider using it then.
I did however just start my car up for the first time since Friday afternoon, still had plenty of juice left in the battery and the engine did it's normal pissed off to be in the cold noises but it started and eventually got to op temp.
I just get paranoid with the batteries in the winter ever since the last Marquis. That car was so unpredictable in the cold and would just go through them. I will say the "Big 3" has done wonderful things for the mark this winter.
Yes it's for people that are wimps obviously
My first 300D even had bad Glow Plugs, I didn't plug it in. My '71 R/T Challenger had no Choke AND a big gaping hole where the heater core used to be. Yet I drove it for 2 years straight thru winter, cracking the windows open to keep the windshield from fogging up![]()
Shoot pics of ur big 3 setup due that i will b doing it in 2 weeks.
Yeah sorry but I guess I forgot I'm on a board of some real lightweights that drive Luxury Cars and can't wait for heat during the winter![]()
relatively speaking, I'd say you're in GREAT shape!....imo, do away with auto lamps, esp. if you have HID conversion...just use the rotary sw. for lights...btw, what year/model mark? pics!!!Purchased my first Mark VIII just over a month ago, pd. $2200.++ very clean but needs more mechanical than antisapated. So far replaced tires and cleaned as much corrision build up on wheels, still have small leak. Replaced catalytic coverter, 4 6x8" speakers, auto antenna. Biggest prob. is an electrical issue with daytime auto lamps, not turning off unless horn relay pulled. auto locks, all interior lights not work when doors open or switched on. Work in progress.
how's that work? do you Fla drivers still not need ins? registration/emissions?you just swap tags and you're legal/good to go?YesterdayI took the tag off my White 98 and put it on the black car. Visited my cousin and put another 150 miles on it.
I think I blew a head gasket - compression test will tell me more.....
it wasn't today, but I got these awhile back...4.5'' bolt patterns
now I haven't worked on the suspension before, but I'm hoping this will be a simple remove and replace job...when I have the time
