Hey all - update on a few things.
Diff Project: After trying 2 shops, 3rd time is the charm I guess. Finally got a guy who could press in the large subframe bushings, without damaging the powdercoated frame or marring the cups. So what was supposed to take a few weeks has turned into a few months after the thread repair, subframe work, and finally, assembly and drive shaft!
Diffs side-by side - Mark8 diff is 3lbs lighter than the stock LS unit!
Subframe ready to go in. Cleaned and lubed the powerflex 17.5mm bushings.
Mounted in the car, then the diff went in with the use of a jack.
After the diff went on, it was time to reassemble the rear. Spindles with new bearings/studs, axles, control arms, toe links, and new sway bar links. Ended up using Superpro TRC1085V, they are for an FJ Cruiser and have a horizontal and vertical link, adjustable, so great for the coilovers. I also had new holes drilled in the stock bar to increase the spring rate. Hoping this will help me launch a bit harder and keep body roll down even further.
**NOTE - the vertical link is an M12 stud, where the stock links are M10. You will need to enlarge the sway bar mounting holes to run these links. **
While waiting for the subframe work, I decided to tackle a few engine bay changes, long deferred.
Finally pulled the IM and installed the EGR block off plate on the exh mani:
While the manifold was off, I decided to freshen it up with a few aesthetic and functional updates.
- Finalized sanding the engine cover bracket mounts, and painted the upper manifold
- Also painted the K&N inlet tube to match, and grabbed black clamps.
- Gathered the coated lower plenums, snout, and EGR block-off for assembly
- Measured all hardware and ordered some ARP SS bolts to replace the tired stock hardware
- Cleaned and degreased, installed new gaskets on rear cover, snout, and 8 intake ports.
- Fabricated an aluminum heatshield for the underside of the manifold
- Wrapped the shield in reflect-a-gold tape to further manage engine heart.
- Deleted the TB coolant hose, rerouted degas feed and cleaned up some other hoses/wiring in the area
- Simplified the stock plastic vac lines from TB > Fuel Press Reg and capped unused ports for EVAP
Overall, the new look is more simplified and clean, with a little show/flare.
ARP Hardware for TB, Rear cover, snout, manifold, fuel rail, and some other engine bay brackets
All back together
With the car back together, it was time to do a test start to check for leaks, bleed coolant, and get the battery back to life. Oh and hearing it start with open downpipes was nice too
Took the extended down time to also modify the driver vent to accept an SCT mount, and tuck the wiring through the defrost vent. I am running a 90* OBD2 cable extension to keep the wiring from hitting my right knee when driving. With the battery back on, I updated the current tune for the soon to be enjoyed 4.10 rear-end.
Finally, big thanks to Dkmac / Donny for sending me these manual pedals. Successfully "De-powered" my pedals and did the manual swap. Saving another 4lbs by ditching the motors associated bracketry
So - Another 20+ pounds off the car
EGR - 4lbs
EVAP - 12lbs
Pedals - 4
Diff - net 4
Driveshaft Net - ?? TBD ??
Car goes to the driveshaft shop tomorrow for final measurements and fab. Hopefully next week Ill have it back on the road to enjoy before winter officially arrives.
Thanks for checking in!
