ford nut
Local nut case
Anyone know of a good freeware enclosure program? I want to design this box and get er built.
Have no idea how good it is.
http://www.ajdesigner.com/speaker/index.php
small sealed = the best sound quality and most accurate and even levels across a huge range of freq's
with the same sub, a sealed box will be have a much more even range of freq's as long as both boxes are built right, plain and simple, a ported box CAN NOT have a even range of sound, its going to have a sweet spot where everything in the range is boosted, which is why you dont see too many people in SQ comps using ported boxes (and winning).Not necessarily.. Depends on sub and box specs
] much louder but only in a smaller range of freq's, little less SQ because of the range of freq's that have been boosted (the freq that the port is tuned to)
no, that is not true, the port will have to be tuned to a specific freq, and that freq (and the freq's near it) will be boosted, outside of the "tuned" range(which will be fairly narrow compared to the full range of the sub), every other freq, will be much lower in volume. it is impossible to have a port tuned to the whole freq range of the sub.Not true at all.. If tuned correctly the subs will hit the same freq as the sealed box.. again it comes down to subs and box specs..
no, that is not true, the port will have to be tuned to a specific freq, and that freq (and the freq's near it) will be boosted, outside of the "tuned" range(which will be fairly narrow compared to the full range of the sub), every other freq, will be much lower in volume. it is impossible to have a port tuned to the whole freq range of the sub,
This thread really makes me want to replace my stolen sub. Sometimes I can convince myself I don't miss it that much, but its a losing battle. I'm tempted to just get a bazooka tube, they have 10" ones with 400W peak for $139 online...
Hard to build anything decent for $150 that includes sub, amp, and box. Ive got other hobbies and projects that are consuming my cash. Plus I'm not a bass junkie or aficionado like some on here.
Loud knows his stuff....he does it for a living.
I used to also.. for 6 yrs.![]()
yes i do, show me a video of a box tuned from 90Hz, all the way down to 30Hz, show it getting metered, and show us all that there is no freq's that are getting boosted or enhanced, i want to see a chart of freq vs Db, and when i see this magical ported box that doesn't have a sweet spot so i can ask the builder what freq he tuned it to, i want to hear him say "all of them"Wanna bet?
yea well ive been doing this for over 10years, and have trophies, training, technical information, feedback from companies that make this stuff, and happy customers to back it up.
in those 6 years, how many boxes have you built, over fifty?
thanks, now you have showed every body that does know whats going on, that you haven't a clue.
I still have an old bandpass box with two orion xtr's....LOL.
really, how many SQ comps have you won with your ported boxes? every comp ive been to ive seen sealed boxes that take the cake, you do know that there is a difference between SQ & SPL right?u said no one was winning with ported tuned boxes.. my reply was "Wanna Bet?!" And i have trophys to prove that :q:q:q:q. ..
yea, i can see how too many words would start to get to you.So with that said.. All that other :q:q:q:q u typed was a waste of words bro.
yep, you right there, i guess its hard to be able to tell which one of my comments you where challenging, sine you quoted a couple of different ones with no direction to them, my bad. i will try to better decipherer the meaning of your comments by reading your mind next time, cool?YOU dont have a clue what the original bet was about.![]()
No, that clearly started when you thought that you HU was super sweet because its over 8 inches ("biggest on the market")Now the Penis measuring starts huh..
Plus the fact that my screen is 8.5 inches.. (biggest on the market right now)
So Pete. Is your box done yet???![]()
Going to pick up some plywood from HD today, along with the liquid nails
Wanna bet?!![]()
Going to pick up some plywood from HD today, along with the liquid nailsi would go with good old wood glue, construction adhesive doesn't tend to hold up to vibrations as well, and wood glue being thinner will soak into the wood grain a little better for a stronger hold
Thanks bud. Gorilla glue? Or just plain old yellow wood glue?
I'll have to pick up some bar clamps too...
What do you do for spacing between screws? Every 4"?
